Jaguar XE lcd dash flickering
Received 3,929 Likes
Based on what I am seeing, it is looking like the backlight to your LCD is going out and that is causing the very light image that you are seeing. As for the fix, most likely you are looking at a broken solder joint that would need to be touched up and fixed. Not sure how you are with electronics and soldering.
LuanXE (03-11-2023)
Jaguar Forums Editor
XE ( X760 )
08-15-2016 06:20 PM
