Jaguar XF 2015 (250) Sat Nav update
SimpleSailor (01-26-2024)
I can't give detailed instructions as I haven't update my map.
I believe your model XF 2015 uses the same IAM gen 2.1 infotainment system as my 2016 F type.
As well as obtaining the map update on a USB memory stick you need to have an activation could which is generated by using your VIN number, this usually is purchased from the supplier of your map update memory stick
Official versions from Jaguar are about £170
Jaguar sat nav update
