JPEC Year 13: VM of XP or W7 and Flash?
I got a copy of the JEPC Year 13, plenty for my '07 X150. I got it working on W10, but of course Flash doesn't work unless modified to work on W10.
I'd like to avoid running Flash on my system under W10.
1. Does JPEC 13 work natively under a VM of XP or W7? And without needing modification to whatever Flash operates under XP or W7?
2. If so, and I use a VM that incorporates Flash, am I at risk of Flash's weak security if the VM of XP or W7, operating under W10, is active?
Thanks!
Thanks!
A bit of searching will find your answer?
Try this thread as it gets pretty complicated and there is no point in repeating it all over again.
JEPC Install
JEPC Install
panthera999 (12-22-2021)
JEPC Install
JEPC Install
Have a great holiday!
Panthera
I have JEPC and JTIS running directly on my dedicated SDD v1.50 laptop (Lenovo T430) which has Windows 7 Ultimate installed. Both were also previously running under XP Pro before I upgraded my diagnostics laptop and SDD version.
Never thought I'd be digging in a box for the dusty old W7 install disks, let alone the XP ones...
Got it to work. Awkwardly, but for something I use a few times a year, just fine. Issue is getting JPEC to display *.png picture files. Blocked by security settings.
Install Win 7 Ultimate using Virtualbox.
Download JEPC '13 and install under Win 7 VM.
Problem: photos being blocked by Win 7's Internet Explorer 8 (?) release.
Opened Win 7 VM internet options "Security settings".
Set lowest available level of security.
Set all Active X security restrictions to "Enable" (meaning I shut them off or turned them on as appropriate to set minimum or no security).
Back to JEPC. Select Jag part image at end of tree: Select "fullsize image" icon.
"....Click here to change your security settings" >>> "Active content blocked" >>> "allow blocked content" ... Security warning "yes". Pic appears.
(Until the above security settings were disabled, JEPC's *.png pic would not appear.)
Shutoff VM Win 7 internet access, since it's only ever used for JEPC.
Anyone know how to get the *.png image to appear without the security warning dance, please post. Thanks!
I'll post this at the end of GGG's thread as well.
trosty
08-12-2015 10:44 AM
