Lower oil pan gasket leak
Old 03-12-2008, 04:55 PM
Michigan's Avatar
Default Lower oil pan gasket leak
Can anyone advise me as to how hard it is to change a lower oil pan gasket, I have a leak onmy 1998 XJ8 and my mechanic advises replacing it. Any specialist tools required?
Thanks,
Michigan.
Old 03-12-2008, 04:59 PM
Default RE: Lower oil pan gasket leak
All you need is a 13mm to take out drain plug and an 8mm for the 20 oil pan bolts. Piece of cake. Make sure you orient the pan gasket correctly on install.
Old 03-12-2008, 08:12 PM
will your there replace the4 orings 2 inches above the oil pan in the front of the engine .. the orings are blocked by a plate i think 13 mm .. they also give false oil pan gasket leaks
bamforp
09-26-2021 08:04 AM
aholbro1
08-05-2021 05:02 AM
Rivguy
12-04-2020 07:55 AM
Wes Steenrod
09-06-2015 06:52 PM
Dymaxxion
09-04-2015 02:40 PM
Quick Reply: Lower oil pan gasket leak
