MAF cleaning
Received 3,910 Likes
MB, you want to let the cleaning fluid run over the wires inside the MAF, but you don't want to spray them directly. They are fairly fine and directly spraying them has a chance of breaking the wires. They do make special MAF cleaners that come in a spray can, but you can get away with carb cleaner if you don't have any MAF cleaner.
Just make sure that you get all the fluid away from the wires prior to starting. If you don't, it can cause the MAF to sense the wrong air flow and lead to other issues.
i have maf cleaner but when i took the sensor off it was just like a tube with 4 things connecting to a hole in the middle? do i spray it in the hole? lol idk what to do. i thought the maf sensor was right before the air filter. ![Name: P1300003.jpg
Size: 86.3 KB](https://www.jaguarforums.com/forum/attachments/general-tech-help-7/183077d1501312698-maf-cleaning-p1300003.jpg)
i found this picture on the forum this guy is selling. on the other side theres an opening is that where i spray it in?
haha yeah my friend had found his car listed somewhere and it wasn't even for sale and scammers suck.
It's ok I also have it listed on this forum too. lol
https://www.jaguarforums.com/forum/s...ad.php?t=11573
thanks carguy for the picture! haha just so i dont mess anything up. all i do is take off the sensor spray the crc maf cleaner into the hole only on the sides not directlly down. About how long should i let it dry before re installing? and about how much crc should i spray in? i had a xj-6 before the xjr and it seemed stuff was always breaking so im just being cautious. Ive had pretty good luck with xjr so far!
shootingbrake
09-23-2015 10:54 AM
