Minimum compression for engine to start
Not a Jaguar, but my son's 2003 Nissan Pulsar/Almera. For some reason this car will not start. Was running fine until a couple of days ago. A few weeks earlier the car had failed to start and I diagnosed engine flooding. Cleaned the plugs and let the cylinders dry and it started fine. Now nothing. I have checked the valve clearances - all OK. Ignition - a big fat spark on all cylinders. Pulled the cam angle sensor and all seems good. Sprayed starting fluid - absolutely nothing - not even a cough.
Now I measured the compressions and they are way down. One cylinder is at 55psi, the others 75-90psi. I am at a loss to see why the car will not fire.
Question then is how low a compression does a modern car have to have before failing to start? After all, many pre- war engines would have a compression pressure in the 75psi range.
Received 3,929 Likes
Mekon, from what you describe, I would be looking more at the timing of the car than compression. From the sounds of things, you have jumped a tooth or two and this is causing the valves to open too soon, killing the compression. This will also lead to hard start/no start conditions. Checking the timing should not be too bad as you simply have to remove a cover off the front of the engine to expose the timing marks. This is where having a manual on the engine will then tell you when your crankshaft is at XX position, the camshafts should be at YY position. Every engine is different. hence why I say to look in a book for the exact details. Also, you can determine which gear jumped as most cars have colored links (may be silver, may be dark, may be painted a color) that the timing marks should match up to. Again, the book will clarify how the colored links should appear
Fast71SS
03-31-2017 08:23 AM
