Module Experts
Hi has anyone used Module Experts in Jacksonville Florida ?? I have been working on a Friends 2005 X Type originally he went to the local Jag dealer because the voltage regulator was causing a parasitic drain on the battery the voltage regulator is part of of the ECM and yes he needed a new ECM cost 2K which I understand Module Experts said they could fix the problem rebuilt ECM 637.00 have had nothing but problems this the 3rd attempt to correct the problem and yes 3 months latter I have a car that doesn't run Gear Box Fault = no crank now cranks but doesn't start , had the instrament cluster reflashed as well as the key and yes I am a retired auto tech and used both of my Pro Autel and Launch scanners which are bidirectional can't find any problems , don't use them!!! any feedback would be helpful thanks Joe
PCM, TCM, PATS, etc. all need to find harmony and sync together or no dice. You can't simply replace a ECM and expect all the other modules to recognize it.
Just my $0.02
Your Right , but all my modules do line up , they said that they used a 3rd party to repair my ecm , I do have the capability of using my J2534 to reflash the modules but the problem lies in the software they used to repair ecm the moral of the story is"" the sweetness of low price is soon forgotten " I tried to save someone money just wondering who else has used Module Experts to repair there Jag and there feedback thanks Joe
You need to give more background and why you think it's your ECU
Jagman1984
35
05-22-2019 05:41 AM
