mongoose v139 install
I wonder if anyone can shed some light on my problem,
ive just recieved my mongoose pro cable v139 main disk to install as per online tutorial which seems simple enough
however i cant install as my laptop runs windows 7 64 bit and needs to be 32 bit,
does anyone know a way past this, in simple terms please
Assuming you have a clone and not the genuine Drew Technologies Mongoose?
If so, in simple terms you need to install it in a Virtual Machine (e.g.Oracle VM Virtual Box or VMware Player) with XPpro as the OS which does NOT have an internet connection.
(I have version 1.34 running in Windows XPpro in Oracle VM Virtual Box on my Windows 10 laptop)
If you don't know how to do this then it immediately gets very complicated.
See this thread for extensive discussions:
OBDII Code Scanners ** Member Approved ** - Jaguar Forums - Jaguar Enthusiasts Forum
fingers (09-06-2015)
Windows 8.1 doesn't seem to be able to find any drivers for the Mangoose so I can't load any and I have tried installing the 64bit ones on the DrewTech website. The virtual XP PC sees it as a USB device and when I try and add it I see it flash up very briefly then disappear. If I try again it just says it is busy from a previous operation.
Do I need to get Windows 8.1 to recognise it first or does it not need the drivers loaded in the guest OS?
philwarner
43
09-10-2023 11:30 AM
trosty
26
12-18-2022 06:40 PM
aholbro1
08-05-2021 05:02 AM
