More On Vibrations
Old 05-24-2022 | 10:47 AM
Beauxmont's Avatar
Default More On Vibrations
Very noticeable vibrations when idling in Drive. Not so much when in park or neutral. Also not as much when A/C is turned off. New water pump and new manifold parts. Would appreciate input.
Old 05-24-2022 | 10:48 AM
Beauxmont's Avatar
Forgot to add that it is a 2013 XF with 63,000 miles.
Old 05-25-2022 | 03:42 AM
Welcome to the forums Beauxmont,
119 Views as I write but no one had a go at a Reply. You are more likely to get advice from members with the same model by posting technical questions in the X250 forum.
Assuming the engine has a smooth and regular idle, vibration could be caused by a loose or failing engine mount (2) or transmission mount (1). Another possibility is any pulley driven engine ancilliary with a worn bearing or the same in the idler pulley or drive belt tensioner.
CzechFrank
XF (X260)
03-27-2018 11:35 AM
CzechFrank
02-22-2018 06:47 AM
Radogabo
08-02-2017 12:07 PM
Traveller
05-12-2017 11:09 PM
nsl1
05-10-2014 12:15 AM
Quick Reply: More On Vibrations
