MY17+ CCF Edit
Can't help with the original question I'm afraid but if you can do older vehicles do you know if the CCF can be used to disable the seat belt warning chime? I would love to kill this on my MY14 F Type....
The following 2 users liked this post by RegGraham:
Aarcuda (04-25-2020),
Hasibur Rahman (04-20-2020)
Sir I want Pathfinder CCF editor
thanks in advance
Not a problem do you have Pathfinder and a suitable interface?.
If so I'll send you my PayPal address if you are interested I am charging £100, it's easy to install and use I provide easy usage and install instructions. Once you have it install it and follow the instructions to et the license unlike others I send the license I don't log in to set it up.
Regards.
Reg.
Regards.
Reg.
Mohamed Abdelrhman (11-23-2020)
Regards.
Reg.
Regards.
Reg.
I hope you will understand me . First thing in Bangladesh doesn’t has any branch of Paypal.
I can not send you money .
Then I just join in a workshop and I am Junior of you . My Boss has a small workshop I work there as a junior technician. My salary also low . I want that software for getting experience to work with it . I thought it a free software. Sorry Sir I can not buy this software from you . I am unable to pay you .
I hope, you will understand my mind . At least can you send me user manual .I want to learn how it’s work .
thanks in advance.
It is only the Chinese sellers that seem to call it SDD2 it has nothing in common with SDD it doesn't even support the same vehicles even though they seem to say it does. I have tested it on a MY17 XE and it would not recognise the vehicle.
Pathfinder is the new software that JLR introduced in 2017 for all vehicles that use the DOIP (Diagnostic over IP) interface. If you are working on a MY18+ vehicle then you will need a suitable interface either the JLR Bosch DOIP, the DA-DOIP from Diagnostics Associates and there is another one from flyOBD but I'm not sure whether this is just a chines copy of the Bosch one. There are Chinese copies of the Bosch one although not 100% copies.
You would need a laptop running either Windows 7 or Windows 10 X86 or X64 then just download the installation program from Topix http://diagnosticdelivery.jlrext.com...Updater_v2.exe run this and it will install the connect application which will then install pathfinder. Install the drivers for the relevant interface and you are ready to go. You then need to create an account on Topix at https://topix.jaguar.jlrext.com/topi...cle/lookupForm you can then select register.
There are hacks available to avoid paying a subscription for module programming, Pathfinder doesn't offer full CCF editing as SDD did with cracks but I offer a standalone application for that purpose at £100.
No if you try an unsupported car it tells you to use SDD although I now have the two on separate platforms since upgrading to Windows 10. I have Pathfinder on Windows 10 64bit and SDD on Windows 10 32bit I had horrendous problems trying to get SDD working on 64bit Windows. SDD will tell you its a legacy vehicle if you attempt to connect to a newer car even if you are using the DOIP interface.
Thanks so much for your detailed reply's!!
Just a note but I have SDD working perfectly on 64bit Win7. Also getting all updates as I stay connected to the internet. I am still getting them but waiting for that to stop or error out.
I was told not to do either of those things?
Looks like for my 2014 XJ I can stay with SDD.
The only niggle I have found with SDD is that it is a lot less tolerant of Battery Voltage, fir doing things like putting brakes into service mode I still had to have the battery at 12.75V whereas on Pathfinder I could do it at 12.1V which meant on the XE I did the brakes on the other week I had to connect up all of the battery support stuff as it would not let me put the handbrake into service mode yet on the F-Pace I could just quickly get in the car load up and go.
When you do eventually have to move to Windows 10, as windows 7 will not receive any new security updates existing ones may still be downloaded, you will be better to do a clean install and not try an upgrade the upgrade failed twice in the end I set up a test machine and upgraded that and it left SDD in an awful state.
Has anyone gotten SDD to work on Windows 10 32 bit? I got it to run on 64bit but the the VXDIAG driver doesnt' support windows 10 64bit. So I tried using it on a new Windows 10 32 bit version and am getting an error about the side by side configuration is incorrect. I also have to run it in administrator mode. Weird. I am using SDD 1.59.
Have you tried using compatibility mode to install it?
win10 Compatibility Mode
I have had some luck with this.
good day colleagues. there is a special program for editing ccf edition. well, since we are all gathered here, I want to pay attention, of course I understand everything, but I don't understand why there is active help for money????? then let 's also make all the tips paid ????? if you can help, do it without money...........
