There is another noise filter in the wiring, plastic-cased and clearly marked "noise suppressor" but, in thinking about it, I have recollections of some cars using two suppressors back in the day.
I thought this widget was especially weird being wrapped in electrical tape; it has a home-brewed, mad-scientist look to it.
As an aside I'll mention that, after dabbling about on a couple of these old Ferraris, I've concluded that the Jag guys and the prancing horse guys must've been cousins. The "lay-of-the-land" is similar in many respects
A few years ago a mate asked me to "look at" his 1972 DS21 Fuel Injected Citroen, not running. Uses the Bosch D Jetronic EFI system, same as our PreHE stuff.
Strange car, in a quirky way, but NO injector pulse, sounds familiar.
Theirs is SO simple. A cassette slides into the Bosch distributor, below the Ignition points plate, and contains 2 sets of contacts, that operate on a lower cam on the shaft, and that triggers the EFI system. He had oiled the shaft, and a drop must have gone down through and was sitting on one of these contact points. Sprayed it off, refitted the cassette, started right up.
He wanted me to sort the electric/hydraulic pre-select gear change, HAHAHAHA, a V12 rats nest is SIMPLE compared to that fiasco. Never got it spot on, but it worked enough to drive it, and he never asked anymore.
