Need Help! "Connect your iPhone" Apple CarPlay Issue
Apple CarPlay is now not working via USB lead (it worked fine originally). When I plug in, it senses USB connection and prompts "switch to CarPlay" which I select. The CarPlay section of main screen then shows my iPhone description/name for about 3 seconds, then switches back to "Connect you iPhone". When I select the CarPlay app, it then reads "Connect your iPhone" and "Make sure the USB cable is connected properly". I have tried 3 USB cables, plugging/unplugging, hard reset on the iPhone, disabling bluetooth. The car had first service a couple of weeks ago and whilst main software was current, some "workshop modules" were installed and I'm not sure if they may have caused the issue. I wanted to check if any other owners have had a similar issue before I go back to Jaguar service dept. Any feedback/suggestions gratefullly received. Thanks
azeemj
XF (X260)
08-03-2021 06:18 PM
