New here
Grant Francis (07-08-2019)
The prefix XJ stands for Experimental Jaguar and were the factory codes assigned to models from the mid '60's. The X codes started under Ford ownership from 1990 and continued under the present Tata ownership.
Your 2001 XJ8 VdP is an X308 produced 1997-2003.
I think I've posted the list of X codes before but it is relevant to your question.
The following 3 users liked this post by GGG:
https://www.jaguarforums.com/forum/g...rchives-65926/
The fuse and relay layouts are in the Vehicle Care Handbook - part of the original vehicle document set.
The following 2 users liked this post by GGG:
Mrjay622 (07-09-2019),
shekellorie (07-09-2019)
Thanks again Graham
I'll have to fire up the laptop to save that information.
Found the fuel pump relay now looking for the fuel injection relay.
I want to do a compression test on this Engine before I invest any money into it. I'm not sure if pulling the relay for the fuel pump will disable the fuel injectors.
Thank you
Graham.
Thank you
Graham.
Mandrake
09-20-2023 12:58 PM
XJ 4Ever
08-16-2017 06:51 PM
oclakerfan
07-14-2015 08:18 PM
