New rear tires 2016 XF
Howdy from north Texas !!!
Today I had two new tires installed on the rear same tires that came on the vehicle new !
This vehicle is not stable at all in fact acting squirrelly I’m a mechanical type guy operated heavy equipment and drove trucks all my life anyone have a clue what’s causing this ? This car has 47000 miles on it !
pwhjrxf (11-16-2019)
Welcome to the forums pwhjrxf,
Handled correctly BEFORE - unstable AFTER. It has to be the tyre replacement or coincidental failure of a suspension part. In any event, it needs immediate investigation for your own safety.
A badly balanced wheel usually causes vibration but doesn't affect handling. Possible causes of the handling issue you describe are:
1. wheel not bolted up correctly - loose nuts or wrong torque
2. rim not seated squarely on the hub
3. wheel distorted or cracked during tyre removal/fitting
4. tyre fault
I'd get straight back to the shop which did the work and give them the opportunity to check.
4. tyre fault
The vehicle was fine before the tires replacement !
This vehicle goes back and forth to Dallas five days a week pretty much open road ! My wife was driving it last night when this happen she knows her vehicle and is a motor head too ! I drove it hard last night for an hour different type of roads and speed ( Heavy On The Speed ) 😆😆😆 !!! It felt a little loose when I first started driving then it drove and handled like always !!!
The rear end mechanical looks fine as it should it only has 47000 miles ! I’m going to torque the lugs and check tire pressure’s again !!! Then drive it !!!
Thanks for the replies it had me puzzled !
bristimjet
12-09-2013 02:32 PM
