New SDD crack.
New SDD crack, exml decode, VID block editing, engineering mode password
Ok, it was a long and cold Russian winter.
I wasn't able to test a tunes for a Jaguars and i've decided to take a closer look on SDD.
The results are:
-New SDD crack. works with any SDD version (up to 141). Actually it's not a crack anymore (no exe files used, app.war remains original, e.t.c), it's a certificate, which is valid for a 6 month, with a FULL SDD subscription. No topix login/password needed, but all functions works flawlessly (updates, keys programming, engineering mode)
Two options are available - one is infinite for selected version of SDD, another one is a 6 month cert. In first case all you need is to run a .cmd file, in second case - you need to run a javascrpit file (you can view it, it is harmful), it will get you machine ID, when i'll recive it i'll be able to issue a certificate.
-Password generator for an engineering mode. Including following options:
Jaguar - VIN BYPASS, VID EDITOR,ODO APP,CCF EDIT,ODO APP1,SWDL,ODO APP2,RECOVER KEYS
LandRover - CCF_EDITOR,L316_ODO_APP,TAIWAN_VEHICLE_UPDATE,SOFT WARE_DOWNLOAD,L322_ODO_APP,L322_RECOVER_KEYS,L322_ ERASE_KEYS,
OPTION_8
These passwords can be used one time only. You give me a VIN and SEED, i give you a password
-exml decoding. Now i'm able to decode any exml file to xml and vice versa. xml can be edited (this gives a lot of options for, i.e. editing a CCF of newer cars or modifing a IVS archive to be able to flash any tune into any module)
-.vbf files CRC correction
-VID block editing. Now i've documented a contents of a VID block. Gear ratios (including rear end ratio), regional settings (i.e. to disable a CEL in case of a wrong readings of the secondary HO2S) and many more.
For a first 3 persons - it is for free
And i'd like to hear if there's any decent price for all of the above options (i mean if i can sell it )
Again, it's not commercial topic. At least for a while.
P.S. Back to the tuning, some news are coming as soon as i'll finish a tests of X351 XJR-S and 380hp XF AWD.
The results are:
OPTION_8
The following 8 users liked this post by MoscowLeaper:
18511990012 (05-09-2022),
Albert J (05-14-2015),
alessandro64 (05-29-2015),
jlr sdd (04-04-2015),
Panthro (06-01-2016),
and 3 others liked this post.
I found that the crack from v135 still works OK the current version being v141 cracked OK.
However if all you want to do is modify the ccf file you don't need a the engineering password. Having installed SDD in the Runtime directory of SDD there is an html file named SoftwareDownload once you have been able to connect to the car with whatever interface you use you can exit the SDD browser session and just double click on the softwareDownload.html file. Set it into engineering mode and you can then do most or all of what you want to any JLR.
I will try and set up a little screen capture session and post it so people can see how to do it..
Check the size of the app.war before and after a crack and you'll see why this crack will disable a lot of functions, especially for 2010+ cars.
I know about softwaredownload, but try to change any, say, emission or security parameter in ccf. It won't download to all modules, some of them will have incorrect ccf and revert to default functionality. Also, using softwaredownload you can't flash a module if it already have a latest f/w release.
Save it as a .vbs file and run
Set objWMIService = GetObject("winmgmts:\\.\root\cimv2")
Set colItems = objWMIService.ExecQuery("Select * from Win32_BaseBoard")
Dim fso, tf
Set FSO=CreateObject("Scripting.FileSystemObject")
Set tf=FSO.CreateTextFile("deviceid.txt")
For each objItem in colItems
tf.WriteLine( objItem.SerialNumber)
exit for ' do the first cpu only!
Next
Set colItems = objWMIService.ExecQuery("Select * from Win32_BIOS")
tf.WriteLine (objItem.SerialNumber)
Next
Set colItems = objWMIService.ExecQuery("Select * from Win32_Processor")
tf.WriteLine (objItem.ProcessorId)
Next
I ran the VBS and below is the result, I have just downloaded the 141.02 update but haven't got round to installing it yet I've been busy with my old Freelander 1 rear camera,cruise control and sat nav upgrade. Being unable to use SDD on that model makes life very difficult I'm even having to take it to a specialist to get some reprogramming done..
Result of .vbs
None
Parallels-56 82 A4 4D 79 4E 46 76 BB F3 34 7B C0 59 F0 9B
BFEBFBFF000206A7
I run all my auto software in Virtual machines means I can snapshot before trying updates etc, so I currently have two add vm's as the 140 upgrade failed and their fix didn't work either so I reverted back to 139 and installed a complete new VM.
Result of .vbs
None
BFEBFBFF000206A7
Unfortunately i can't make a certificate for a VMs, since they gives a completely wrong HW id's.
Here's an example of output for a physical PC:
1ZF3Y8862GC
L3E9536
BFEBFBFF000006FA
1ZF3Y8862GC
L3E9536
BFEBFBFF000006FA
I found that your script is included as part of the system to obtain the same information, I believe this can be modified to output what ever details I want it to. All the system identification is done by VBScript so their out puts can be modified to output whatever details you want the application to receive.
SDD uses a java routine to gather a h/w information, to modify it you'll have to rebuild a whole app.war file (and you'll need some libs, which are not available).
The .WAR file is just another version of .JAR specific to Web applications. On a MAC it can be opened without installing the JDK, and scripts can then be modified happily.
I need to spend some time looking into what does what now before I make changes.
It also explains why the system info screen still works on my 139 VM and not on the 14X VM it's all java from 140 onwards
If you decompile them it's unable to compile most of them back.
jlr sdd
The results are:
OPTION_8
The results are:
OPTION_8
jlr sdd
SDD till works on v141, but...
I guess this certificate has to be renewed after every new version as well?
This is Great Stuff !
[QUOTE=MoscowLeaper;1186732]Ok, it was a long and cold Russian winter.
The results are:
That is quite the development from "MoscowLeaper"
Completely functional solution to V141.xx
I sure would be interested in the use of it and wouldn't mind paying for an indefinite solution.
My V139 can't do programming, doesn't open IDS [screen just flashes by].
For years did not have one version that it can do it all like this one.
Contact me if U interested in selling the solution.
Thanks AJ
The results are:
Thanks AJ
sdd139
Hi AJ!
This is probably not the right thread for fixing V139, but if we do not hear from ML it should not be that difficult to get your V139 to do programming. I have only used it on land Rovers, but I guess it is more or less the same with Jaguars. What kind of programming do you want to do? Updating ECU's, calibrating injectors, programming keys? We can go through the installation later if it is neccesary? Cheers!
