OBD2 pinout
Hi, I have a recent model (IPace 2019) and I would like to understand the OBD2 pinout. I can read the HS-Can bus on 6/14 pin, but I have notice that pin 3/11 and pin 12/13 are also connected in the OBD2 plug. Do you know if MS-Can is available on pin 3/11 ? or more globally, what is the OBD2 pinout. If MS-Can is available , what is the speed rate for that bus ?
