OBD2 SCAN TOOL
this question is for the jag techs out there.
I own a obd2 scan tool. Will this scanner work on my 2004 xj8.
I used it on my 98 740i.
Does it make sense if I incounter any warnings to scan and post codes here before I go off to the dealer? I also have the downloaded software that comes with this tool.
thanks inadvance for your answers and advice.
ECM,TCM ANDSRS what are these?
also any thoughts on the cd repair manuals sold on ebay?
just got the car back from jag dealer yesterday they replaced the fuel sender and pump under factory warranty. how much would that have cost me out of pocket if it was not under warranty?
thanks
thanks
Guest
Posts: n/a
ECM,TCM Check engine codes and Sensors Data.
ANDSRS Air Bag codes.
ABS = ABS Codes.
To read the computer check engine codes you need a simple scan tool. But for SRS, ABS, you need a better and more expensive scan tool.
I am starting to see some software on the market that can read SRS and ABS. Just for the software is it about $ 200.00. You won't find a scanner from Autozone or Walmart that can do that. You need someting better.
www.carplugs.com
ABS = ABS Codes.
www.carplugs.com
SD96XJ6L
11-05-2015 10:47 AM
