OBDII Code Scanners ** Member Approved **
#41
#42
So, if the choice was between the AutoEnginuity unit or the OBDCOM unit, which one would people go for? Its seems that the AE unit does it all. However, what enhancements it has over the OBDCOM unit seems to be only useful in some sub-systems that I may not feel comfortable dabbling in. Or, maybe these systems just aren't worth accessing for the extra $400.
Does anyone have an objective answer to this dilemma?
John
John
#43
I got the AE since it could nail down my ABS sensor, to the exact corner, before I started diagnosing the cause of the intermittent DSC fault. If you never want to see some details on systems outside of the basic Engine and Transmission, get a regular sub $100 scanner. Ive found the AE pretty useful for many other things, like watching the o2 trims, and it can see/monitor many specific items in the engine, transmission, and various systems. IT all amounts to money and the value of what you may need it for.
#44
I bought a "Memoscan" U480 from A guy called Tony in UK (tony@mediasave.co.uk). It was only £22 + post. It's cheap and cheerful, but does automatically sense the data format in use by the car. My 2006 S-type diesel turned out to be CAN, and it showed 'no codes'. A good feature is the 33 pages of codes in the hand book. This little gadget is cheap enough to keep in the car, or even have it plugged in all the time, just in case you're chasing an intermittent fault.
Leedsman.
Leedsman.
#46
I don't endorse a product as in this case I've only tested one unit; to give an endorsement I'd have to test at least hundreds of units AND on many cars with proven fault codes to check accuracy of the device's analysis. However I can say that it's cheap and handy, and of course you can take it from car to car as time wears on. Most users won't want to spend hugely on a device they'll only look at once or twice; if you're a semi-professional you'll want something more comprehensive, and there does seem to be plenty on the market in that slot, as exemplified here on this website.
Leedsman.
Leedsman.
#47
John
John
JWestXJR2000 (05-15-2022)
#48
I have been using the Innova 3030 for a while now. It has read the codes on my 01 XKR and my 04 XJ8 with no problems. The book that came with it has a list of all the generic codes, but it will display the Jag codes too. To get a list of the Jag codes, I went to www.engine-light-help.com and and printed out the Jag specific code list and put it in my owners manual of the Innova 3030.
#49
MemoScan U480 for 1999 XJR
Hi guys
I use a MemoScan U480 (same as Leedsman above) for my 1999 XJR - works fine and reads jag specific codes. + would agree as to the code book, it's useful to be able to check general codes without having to go inside and fire up the pc.
Cost about £25 from fleabay so gets my recommendation.
(traced my intermittent misfire with it)
Alex
Alex
#51
John
John
I understand the OBDCOM only deals with the PCM (the engine controller), whereas the AE will do most if not all the modules, including TCM (transmission) and ABS etc. The AE lets you look at hundreds (or so it seems) of sensors all over the car. If you don't need that, don't spend the extra money.
I would guess the OBDCOM will read maybe 30-50 sensors on the engine only. Probably not even the IAT2 on the "R" models, even though that's an engine sensor, because it's not generic OBD-II.
#52
Hello Test Point, I know this was an older post however I just got a Innova 3140 and it displays a P1000 code all the time. Does yours do that and mine also does not go to "test complete" I did run the tool on my mercury and it did fine. Am I missing something? Any advice would be helpful; I thought you might know since you have a similar machine. If anyone has the same problem please let me know. 06’ XK8 Black/Camel
#53
#54
#56
#57
diagnostic trouble code, could be a P####, B####, C####
here's a link with a little more info, keep in mind, jaguar's codes don't always coincide with another manufacturer's when it comes to causes.
#58
Hey guys,
I picked up an ELM327 off of eBay and have it working pretty good on my '04 S Type V8 4.2.
It picked up only one DTC - P1111 indicating an Intake Air Temperature Sensor Circuit Intermittent High Voltage error. Just have to figure out now if this is critical to fix.
I'm wondering which is the limiting factor with these gizmos. Does the unit pick up every code, but the software you're using not know what to do with the code? Or does the unit not read every sensor code?
I was hoping one of these units would be able to tell me which coil(s) I had to replace in my engine. I've got a rough idle periodically and was hoping to find out which one before I took my car in. Now I'm not too sure that my unit will do this. Any input would be appreciated.
Cheers,
Rob
Cheers,
Rob
real22uu (08-14-2014)
#59
Most don't read every code, there are several modules that report codes to the dealers equipment, most of these cheap ones only talk to the engine ECU, it will tell you about misfiring cylinders if the ECU detects them.
I guess the hardware is up to the job, but the manufacturers don't release the protocols needed to talk to any other modules, they have to standardise on the engine control module by law.
As for your air temp sensor warning, I'd say clear it and if it returns, at least check the connector to the sensor isn't dirty/corroded and consider replacing it.
#60
Hey guys,
Cheers,
Rob
Cheers,
Rob
