OBDII Code Scanners ** Member Approved **
#122
I have a OBDII
I use an INNOVA 3100 which has read the generic codes on my '02 XK8 without any issues. Never had the occasion to read the P1xxx codes other than P1000 and P1111. It has freeze frame recording and the ability to upload to a PC based log with supplied software. I caught it on sale for about $80. Here is a link to their web site: http://www.iequus.com/news/news.php?id=13
While I would recommend it, the freeze frame data is not absolutely necessary for the hobby mechanic. Coincidentally, there is an used one on eBay at the moment with a bid of $25 with one day left.
I would appreciate a comment on the OBDII to USB converters with supplied software that are available for about $25. Anyone tried them? I might, just to see. Enquiring minds want to know.
What is the difference between them and the AutoEnginuity generic system for $250?
#124
UPDATE:
The unit is now having connection problems, first noticed today.
Looking at the "AutoEnginuity OBDII" now.
The HK 327 clone may be only minimally useful.
>Hardware- ELM 327 worked perfectly on my 2003 XJ8 VDP
>Software- Proscan 5.0 flawless!! Worked just fine with this hardware bought >in HK for $17.00.
#126
Beaky
#128
Has anyone managed to successfully interface with the Autoenginuity ST06 and Jag specific module yet? Couldn't see anywhere in the posts whether there is still an issue or not. I've emailed Autoenginuity and asked if it is compatible with 1999 XJ8 V8 but, as I've seen in other posts for this on other forums, no response which concerns me that if I have a problem with the product, I'd never get an answer directly from the manufacturer.
Beaky
Beaky
Bob
beaky (11-05-2011)
#129
Thanks for the reply and details of an outstanding issue they're dealing with Bob. I didn't try the tech line, just the sales line. They replied yesterday saying the ST-06 and enhanced Jaguar expansion would suffice, but didn't actually answer my direct question of whether it would interface correctly with my 1999 XJ8 (which is more of a tech question anyway).
At the moment, it is a nice to have rather than a need to have, but know I will be needing something eventually (proactive). I will wait a couple more months, and see if they do indeed get to the bottom of the issue you raised, which shows they are dealing with issues from customers feedback.
It's a nice package at a nice price for what it does , if it does it. Sounds like you're happy with it in general though Bob, which is encouraging :-) (wish I could get smileys to work in Google Chrome). I'll keep monitoring reviews and comparisons for a couple of months before deciding.
Thanks again.
Beaky
Thanks again.
Beaky
#130
I use an ELM327 with Bluetooth and the torque application on my Android. The software works well, easy to setup and operate on my Jaguar 2003 S-Type.
The connector on the Jaguar side is above the knee, drivers side. When the ELM327 is connected, it points straight down, but one could still drive with the ELM module connected. The unit cost me $26.70 including shipping and handling from Amazon, and the only grief I have is, it would be nice to have documentation on how to use it to better understand what some of the readings mean.
#131
The best thing to do is to scrap the software they include, its pretty much a waste. I used proscan 5 instead for the software.
#132
#134
Snap On MT2500
Searching this forum has produced 4 threads that refer to the Snap on scanner but with out any specific info if it has worked or not. Anyone have any info on using this scanner on any model or year of Jaguar? Specifics such as what cartridge, keys, and adapter would be appreciated if it worked.
Snap On doesn't support this tool any longer, but used bits and pieces can be found pretty easily.
Dave
Dave
#135
I got the obdcom, i prefer devices that tie to the pc. I pasted the output from the unit below for anyone that wonders how the obdcom works on the jag.
I got a 2000 xj8 with a new trans off craigslist for 1,000 that had a blown right secondary chain. After the chain went the owner threw their hands up.
I just finished replacing all chains and tensioners, did a comp test all looks good.
Hooked up the brand new obdcom and saved the messages, then cleared them and saved them again.
Keep in mind the car has no plugs radiator etc in it yet, just buttoned it up for a comp test before finishing it off, in case i had to pull the heads for a bent valve.
PS my work encrypted my laptop and obdcom would NOT work with it. Had to get my dell mini netbook and use it instead.
Heres the first set of codes then i cleared them all
******* 12/3/2011 12:40:18 AM *******
STORED CODES
P0102 17
P0102 Mass or Volume Air Flow Circuit Low Input
P0112 17
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P0335 17
P0335 Crankshaft Position Sensor A Circuit Malfunction
PENDING CODES
P0301 17
P0301 Cylinder 1 Misfire Detected
P0302 17
P0302 Cylinder 2 Misfire Detected
P0303 17
P0303 Cylinder 3 Misfire Detected
P0304 17
P0304 Cylinder 4 Misfire Detected
P0305 17
P0305 Cylinder 5 Misfire Detected
P0307 17
P0307 Cylinder 7 Misfire Detected
P0308 17
P0308 Cylinder 8 Misfire Detected
P1313 17
P1313 Misfire Rate Catalyst Damage Fault - Bank 1 (Ford)
P1313 A Camshaft Position Plausibility (BMW)
P1313 Misfire Catalyst Damage Fault Bank A (LandRover)
P1313 Misfire Rate Catalyst Damage Fault - Bank 1 (Jaguar)
P1316 17
P1316 Injector Circuit / IDM Codes Detected (Ford)
P1316 Misfire Excessive Emissions Fault (LandRover)
P1316 Injector Circuit / IDM Codes Detected (Jaguar)
P0102 17
P0112 17
P0335 17
P1111 17
P1111 System Pass (Ford)
P1111 Engine Coolant Temperature Radiator Outlet Sensor Low Input (BMW)
P1111 Intake Air Temperature Sensor circuit intermittent high voltage (GM)
P1111 Atmospheric pressure sensor high input (Subaru)
P1111 If a pending code = system tests passed (Jaguar)
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage (Jaguar)
P1111 O2 Control (Bank 1) System too lean (Audi)
CLEAR-------------------------------------------------------------
Second set of codes - turned key off and on and let the diags run again
******* 12/3/2011 12:44:16 AM *******
STORED CODES
P0102 17
P0112 17
PENDING CODES
P0102 17
P0112 17
P1000 17
P1000 Check of all OBDII Systems Not Complete (Ford)
P1000 Cooling System Heat Valve Control Circuit (Chrysler)
P1000 OBD II Monitor Testing Not Completed (Mazda)
STORED CODES
P0102 17
P0112 17
P0335 17
PENDING CODES
P0301 17
P0302 17
P0303 17
P0304 17
P0305 17
P0307 17
P0308 17
P1313 17
P1316 17
P0102 17
P0112 17
P0335 17
P1111 17
STORED CODES
P0102 17
P0112 17
PENDING CODES
P0102 17
P0112 17
P1000 17
#140
Pardon my lazyness to not read all posts in this thread but I figured this is the best place for my question.
What is the name for the factory diagnosis scan tool that the dealer ship uses?
I have purchased clone's for other vehicle brands with out issues, I'm hoping I can do the same with jaguar but I cant find the correct name.
