OBDII Code Scanners ** Member Approved **
Old 01-30-2012, 12:17 PM
billbjork's Avatar
Default scanner
Innova 3160--tested on chev 06- 3/4 ton diesel abs--05-ford f250 gas engine---06 dodge caravan--06-chrys, pt cruzer-03-Xtype jag --- 04--ford F150.gas ---2000 chev. suburban all with good results.
  #142
Old 02-07-2012, 05:26 AM
steveinfrance's Avatar
I can't see why readers shouldn't work on UK made cars but has anyone used the OBDCOM one on a UK model?
  #143
Old 02-07-2012, 10:40 PM
vacmail's Avatar
OK I pick up the Innova 3130, and I have a 2004 XJ8, But I have a questions When I Plug it up for the first time it don't have any codes great new. But this model do have the EMISSION STATUS lights and it's has the yellow light. what is this telling me, any ideal what is getting really to go out?
  #144
Old 02-08-2012, 09:48 AM
billbjork's Avatar
If it didn't come with a manual the YELLOW means a pending DTC or some systems haven't ran there tests OR CAUTION..
GREEN--is all Ok, all monitors have ran and passed
RED --- DTC are present and one or more systems have FAILED there tests AND the CHECK ENGINE LITE is or should be ON and the scanner should show a DTC.
PENDING
  #145
Old 02-22-2012, 05:40 PM
disguay's Avatar
the ELM327 works great on my 02 x type
  #146
Old 02-29-2012, 11:32 AM
dkeuper's Avatar
I just got the UltragGarage "scanner" and I'm happy with it.
It works on my '07 Xk, '08 Touareg and '05 scape.
My water Temp reading ist 200°F = 93°C and guess that's ok for now.
Will see in the summer if it stays that way.
BTW, I detected some error codes with missfire detection which I cleared and which didn't come back.
I guess it was because of bad fuel, I had a bad idling some days ago after I filled up on the cheapest gas station
in my area.
  #147
Old 02-29-2012, 11:47 AM
Italianguy63's Avatar
I got the Innova 3120 because I have an OBDI engine ('93 Chevrolet Z-28). Tried it and it worked well on my 2004 Dodge Stratus, and my 2006 Chrysler 300. Finally, I tried it on the 2004 XK8, and it showed "passed" tests, but did not give a lot of detail-- but it seemed to work with and identify the Jag codes. I'm pleased with it for the price for sure!! Already cleared a code on a friends 2006 VW New Beetle.
  #148
Old 03-09-2012, 07:22 PM
MrKen215's Avatar
Default AutoEnginuity Not Compatible 1999 XK8 SAE OBD connection
I just spent $500 on AutoEnginuity OBD software only to find out it only works with Jaguar enhanced CAN data. AutoEnginuity told me they have issues with reading the generic OBD code from XJs and XK Jaguars. Which means no O2 sensor data is available. It would be a nice scanner package if it completely worked.
oldjaglover (10-19-2021)
  #149
Old 03-10-2012, 02:38 AM
djdex's Avatar
Wow, that's very odd, how can everyone else offer the standard codes for peanuts and they can't for 500 bucks?
  #150
Old 03-10-2012, 02:57 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
Have used now the Ultragauge on several XKRs (1999, 2000,2001 and 2005), and it works great and is relativly cheap.
It is a neat little unit, that not only has the ability to show DTC's and reset them, but also shows live data so no need for a laptop (i.e. stft/ltft values) and true temps, you can also set alarms to certain sensors.
  #151
Old 03-10-2012, 09:57 AM
ant17's Avatar
remarkable, I paid 25 for mine and so far does what I need.
  #152
Old 03-10-2012, 04:23 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
No idea what could be the issue, but the 99, assuming your CAN network protocol is ISO 9141 (which it should be, assuming its a US car) should be able to work easily with AE. Mine does exactly what it says it should. Its only had issues that I've read, on the earlier XJ & XK models, 96-97s (the first year of requiring OBD II compliance), and ones manufactured for the European markets.
  #153
Old 03-17-2012, 10:48 PM
johnk07str's Avatar
Default Actron CP 9145 works with '07 STR
Used an Actron CP 9145 to download codes and reset CEL on my 2007 STR. I was impressed with the huge amount of data I was able to access. I have had the car for 2 days and got (and hopefully fixed) a lean mixture (P0174 & P0171) condition. I couldn't have had as good of an outcome without Jaguar Forums.
  #154
Old 03-17-2012, 11:29 PM
H20boy's Avatar
fantastic John, glad the forums are proving to be a great resource for you! Don't be afraid to get into the threads (or start your own) and ask questions, talk about ongoing topics, get a feel for the rapport that we're known for.
Start a thread with some car ****, and guarantee you'll get a discussion going we like to see other car pics
  #155
Old 03-29-2012, 06:05 AM
Timboy's Avatar
Default Actron Pocketscan Plus 9550 & X-Type
Can you tell me why this reader is not recommended for the 2004 X-Type?
Thanks for your advise.
  #156
Old 04-05-2012, 10:13 AM
bballarin's Avatar
Default AutoEnginuity-ScanTool-6-0 at $89?
What do you thing about this offer:
Buy AutoEnginuity ScanTool 6.0 - Buy OEM Software Online
is that the same product as the #ST06 product showing with a $249.95 price tag on their website
Order Online
Seem to good to be true...
  #157
Old 04-06-2012, 05:47 AM
ant17's Avatar
I wonder if that software can be used with another brand reader?
  #158
Old 04-06-2012, 07:01 AM
GGG is offline
Received 16,860 Likes on 12,186 Posts
I have AutoEnginuity (the pre-2007 build which doesn't support the Jaguar expansion) and an ELM scantool. The software for both is installed on the same laptop.
The AutoEnginuity scantool only operates with AE software and the generic ELM scantool doesn't recognise the AE software.
Old 04-06-2012, 08:16 PM
CrazyIvan1958's Avatar
I just bought this one (Autel MaxiScan MS-509) as well. It came highly recommended for my situation/car. However, while it will read generic codes, it does not have any real interface with my 1998 XJ8. I'm looking for a reader that actually will communicate with this car, and recognize what it is.
Last edited by CrazyIvan1958; 04-06-2012 at 08:18 PM. Reason: added actual code reader unit
  #160
Old 04-07-2012, 06:34 AM
Hello to everybody
ELM327 Work with a 1999 XK8 ?
just a little question as the title, ELM with proscan 5.9 could work in a '99 XK8 ?
Someone could tell me please definitely if a 1999 XK8 is OBD2 compliant ?
Thanks a lot to anyone who will answer
Jag
Quick Reply: OBDII Code Scanners ** Member Approved **
