OBDII Code Scanners ** Member Approved **
#262
Phil, I don't think you'll find a scanner to diagnose the air suspension from anything mentioned above. If you want that ability, check out the 'dealer clone scan tool' thread, where many have successfully used a chinese cloned drewtech mongoose cable and paired it with an older, genuine version of SDD/IDS (jaguar's tech software). The bundle can be had for $200-$300 total.
#263
I've just got my ELM327 from Amazon for $24 Amazon.com: BAFX Products (TM) - BLUETOOTH - OBDII OBD2 DIAGNOSTIC SCANNER - CAN ELM 327 SCANTOOL - CHECK ENGINE LIGHT CAR CODE READER: Automotive. It's S-type 2005 v6.
It seems to work great with free Torque Android app in my phone.
Reads both live data and errors, however can't say for sure about the errors as it says that there are none. It reports one pending error P1000, it should change to P1111 I guess, but no idea yet how to do that transition.
Will consider getting paid Torque.
P1000 is a generic code that is always present until you run through a full drive cycle. So that is normal. It just means you recently reset power and the car hasn't had time to check everything in the system yet. Usually it takes a few miles.
I also have a Elim327. I've used it on a few Fords and Mazdas with the free Torque app on my phone. It's always worked great. Make sure you get the one from when you buy one. There are a lot of knockoffs out there. I have yet to try it on my 09 Jaguar XF but I'm sure I will eventually if there is an issue that pops up.
#264
I bought a Memoscan U480 off ebay for a tenner, worked great on my 2004 XKR
#265
This seems to work fine. It picked up the PWM protocol and scanned OK. There were no DTCs found, and six or so out of about 10 I/M monitors returned "READY", which is good. About four others returned "N/A". I pulled a couple of sensors and started briefly to try to force a DTC or two, but that didn't seem to do the trick. I didn't want to run for long with any sensors unplugged, so for the moment I'm going to pronounce it Working. It is interesting that OBD-II is present on a 1999 UK model, but I suppose that's high-end vehicles for you! VIN retrieval of course is not implemented.
#266
Avoid this scanner
Autel MS580 from Amazon. Avoid at all cost .
1 froze up shift linkage
2 Threw 2 new codes that were not present day befor @ autozone check
Codes P1642 P1797
3 No downloads avaiable , nor ability to print out.
4 Not Autel {UK} who have a disclaimer on their site
5 China clone
6 Offered 20% discount to keep unit.
** went on Autel Website under Chinacar diag .com found complaint from user in Brunei referencing S/N MS50245 , funny thats the same S/N as mine . Brunei to Texas in 90 days !!!
Returned unit >
Codes P1642 P1797
5 China clone
Returned unit >
#267
new autel maxidaig elite md702 is the one you want to purchase it works for abs,suspension etc.as I stated in a previous post it reads factory codes , this thing even tells you if a bulb is blown but like anything beware of the clones /knock-offs from china because they are out there I very happy and satisfied with the purchased I made it had paid for its self already helping me keep. My 184,000 2001xjr on the road running strong .
[/QUOTE]
[/QUOTE]
MRomanik (03-07-2013)
#268
#269
Engine light not on, Can I still scan?
I want to know If I can still get codes even though engine light is not on? Car is not running properly. Goes into limp mode. I want to get it scanned but wanted to know if engine light needs to be on? As my engine lights on again off again but car still not right.
This list will serve as a reference for those owners who are looking to purchase and own their very own.
Recommended
Take a look at all of the sensors covered by the AutoEnginuity unit.
Please place the vehicle year and model that you know it works well with if you would.
If you're scanner is already on the 'approved' list, but your car isn't, feel free to let us know in this thread.
Recommended
- AutoEnginuity, tested on 2003 XK8, 2000 XJ8 and 2004 STR (enhanced sensor/function availability, for an additional charge (issues with 1996 and older)
- TOPTQK, tested on 2000 XKR and 2003 S-typeR
- Innova 2030, tested on 2001 XK8 and 2004 XJ8
- Innova 3030, tested on 2001 S-Type, 2008 XKR and 1996 XJR6
- Innova 3100, tested on 2002 XK8 (My 3 year old INNOVA 3100 says 'CAN compatible' on the face, has the color coded LEDs and PC link reports)
- Innova 3120, tested on 1995 XJ12
- Innova 3130, tested on 2000 XJ8
- CodeKey, tested on 1995 XJ6, 1999 XK8
- Actron CP9035, tested on 2003 X-type
- Actron CP9175, tested on 2001 S-Type and 1996 XJR6
- Actron CP9180, tested on 2004 S-type
- Actron CP9185, tested on 2002 XKR
- Actron CP9125, tested on 2003 S-Type
- OBDkey, tested on 2001 S-type and X350 XJR
- OBDCOM, tested on 1998 XJR, 2000 XK8, 2001 S-Type, 2003 S-type, 2005 S-Type R and 2009 XF
- CEN-TECH 94169, tested on 2007 XJ8
- CEN-TECH 98614-2VGA Scanner, tested on 2000 XK8 with real time data logging
- CanOBD2 3030, tested on 2002 X-type
- carcode.com software based and cable unit, tested on 2001 XKR and 2003 S-type
- ELM327 bluetooth or hardwired version, with Torque app (for Android), tested on 1998 XJR, 2003 XJ8 and 2005 XJ8,
- Kiwi PLX bluetooth, with Torque app (for Android), tested on 2003 S-Type R
- Memoscan U480, tested on 1999 XJR and 2006 S-type
- ProScan under www.myscantool.com, tested successfully on 1996 XJR6, 2003 XJ8, and 2001 S-Type
- CarCode ODBCII reader from CostCo
- ProScan listed under www.myscantool.com (slight contradiction with a recommendation also)
- Actron Pocketscan Plus 9550
- Auto Xray AX1500 CodeScout
- more coming, I'm sure
#270
I will try and add some screen shot of the autel maxi the reason I purchased it was just to read abs codes which came out to be a short in the wheel sensor wire the scanner picked it up right away also it read blown park light bulbs this scanner paid for its self there is a company in Michigan that sells the authentic autel scanner with a warranty and updates. And yes it will pull codes even if the check engine light is not on.
#271
Einstein
I love Albert Einstein but I've also realized that Insanity can also mean: Doing the same thing over again, knowing exactly what's going to happen, and doing it anyway...
Nothing is perfect however, the one I got from Costco called CodeKey and it has given me every code that my software obd reader did on my 95 xj6, 99xk8 and my 96 Toyota rav4. With your comment I will continue to double check the results. I did find it to be a handy tool to have. Sorry, but until it gives me a bad indication I will not be giving it up. I have usb computer interface that I check it with and it has not let me down yet.
#272
Limp Mode
I'm hoping to get some answers here before I take my Jag to the mechanic. I got a lot of codes yesterday coming from the car:
ATC:
B1676
B1262, 63 & 64
B1242
B1946
B1265...
ABS:
U2502
U2523...
ECM:
P2135
P2582
P1111...
IP:
B2333
B1246
B2882
B1213
DSM:
B1940
U 1940
B2477
ATC:
B1676
B1262, 63 & 64
B1242
B1946
B1265...
ABS:
U2502
U2523...
ECM:
P2135
P2582
P1111...
IP:
B2333
B1246
B2882
B1213
DSM:
B1940
U 1940
B2477
Recommended
Recommended
#273
2005 S Type 3.0 6 cyl
Car is constantly going into limp mode. I have it parked. Going to mechanic tomorrow. I don't want to know how to "clear" the codes. I want to know what the problem is. Here's the codes:
ATC:
B1676
B1262, 63 & 64
B1242
B1946
B1265...
ABS:
U2502
U2523...
ECM:
P2135
P2582
P1111...
IP:
B2333
B1246
B2882
B1213
DSM:
B1940
U 1940
B2477
ATC:
B1676
B1262, 63 & 64
B1242
B1946
B1265...
ABS:
U2502
U2523...
ECM:
P2135
P2582
P1111...
IP:
B2333
B1246
B2882
B1213
DSM:
B1940
U 1940
B2477
#274
#275
Hi Guys,
New to Jaguar,
New to this site,
New to Code-readers.
My Son has his first Jaguar (see sig) so we are both learning on it.
My mate also has his first Jaguar (X-type 2.5 2003 Petrol) which is showing P0171/0174 codes (see my own post; Codes: P0171 + 0174).
I recently bought an AUTEL 905 reader, and only used it a couple of times on these 2 cars, and only for the codes.
As far as I am aware, the reader seems fine, but obviously haven't used it to the full (understatement).
I now believe it to be a copy. I bought it from Amazon and had no idea that they would allow that. Be that as it may, I'm struggling to update it.
I'm hoping someone on here might be able to help me to do that please.
,,,, now,,,, back to my search for help on the codes,,,,
New to Jaguar,
New to this site,
#277
Welcome to the Forum. There's a short qualifying period before you can edit or send PM's
In the meanwhile please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
#278
#280
Thanks Tom. I called Innova this morning and they told me a lot of foreign cars require the car to be actually started.
Being a woman, :-) I had read most of the LONG manual and it specificly said NOT to start the engine. They need to change that in the manual. I'll try it again later today.
