Oil change
Norri (10-27-2015)
Can't fault that logic.
I will add that later model Jaguars run much cleaner than older models. The oil in my XJ6 and XJ12 Series 1's was always black by service. The straight six XJ40 and X300 were similar but to a lesser degree. However the oil in my current XK always looks just as clean when drained at service.
Engine design has improved with closer tolerances as has oil technology (although I'm not encouraging yet another oil debate!) and these together with engine management systems ensure cleaner running.
Received 6,307 Likes
