Oil type - 04 xj8 - castrol or pennzoil?
Old 08-03-2012 | 11:39 PM
presidential27's Avatar
Default Oil type - 04 xj8 - castrol or pennzoil?
I noticed on the engine cap that it says that Castrol is recommended for the engine. Would it be bad if I used Pennzoil synthetic instead of Castrol?
Old 08-04-2012 | 12:43 AM
Mikey's Avatar
Only for Castrol's sales figures. No problem with Pennzoil or any other brand.
presidential27 (08-06-2012)
Old 08-04-2012 | 04:58 AM
Fraser Mitchell's Avatar
My local dealer here in the UK uses Castrol Magnatec Prodessional 5W30. However, if a different manufacturer sells an oil to the correct spec, then it will be perfectly OK. I assume Pennzil is a USA supplier, I haven't seen it here.
Old 08-05-2012 | 06:50 PM
Teck4Jag's Avatar
penzoil is now a subsidiary of rds (shell) should be ok,I'm particular with castrol
X_Type_South_Africa
12-09-2015 06:37 PM
WhiteTardis
09-02-2015 11:32 AM
DeaconHull
08-31-2015 11:09 PM
stanjag
08-30-2015 11:35 AM
Will P
08-27-2015 07:52 PM
Quick Reply: Oil type - 04 xj8 - castrol or pennzoil?
