power antenna mast replacement
This was sooooo simple! Remove the trunk lining and Bam there it is..And 8 mm socket and a phillips screw driver and its out..A few screws and its apart. A new mast from Rockauto PN#LNA4134AA. Throw away the sleeve that come with the mast. Install it from the bottom and have it ran all the way out.
Plug the harness into it and power the radio on then off to pull the antenna in then mount it back it the car.
If you are fast this should be about the time your wife finishes with the brownies....lol
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Please check your forum PM's.
KarimPA
09-03-2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
