Power probes?
Received 10,916 Likes
Received 2,263 Likes
I have (and like!) a "logic probe" similar to this:
https://www.toolsource.com/noid-ligh...-p-101291.html
Is that what you're thinking of?
Worth having, IMO. Essentially you use it like a conventional 12v test light but it's powered independently and glows red for "+" voltage and green for ground. Convenient.
Busa (09-22-2017)
So it's NOT an amount of power tester but rather a tester for the presence of voltage (but calling it power (*))?
Do not use anything that may draw more than a minute amount of power from the signal/device being tested or it may cause codes or damage.
(*) obviously it helps to confuse...
Yes its a tester for the presence of any power and circuit continuity and it can identify positive or negative terminals with some models.
I think it will be a useful tool, so I may buy one.
I'd rather stick to DVOM, OBD & OE-type diags.
Another vote for Power Probe.
Only tool that you can power stuff with and check things no meter can. You can also apply ground with no wire changes. Long enough leads to go from end to end on a car. It's circuit breaker protected so I can repeatably pop the breaker and reset and continue checking where the short is. When I troubleshoot electrical my biggest complaint about my DMM is all the jumpers I have to rig up.
Once you use one the advantages are clear. Like all tools they have some very fancy, expensive versions with many added features.
I have the small case version. About $90.
https://www.powerprobe.com/web-store...-accessories-1
VMM works with IDS/SDD when electrical testing/probing is called for. It's reads into the program. Huge benefits and yes, it's a serious piece of equipment.
