problem aquiring signal to sirius radio
If the antenna is on the trunk lid, possible the cable is pinched. If was port installed sirius, the module should be in the trunk, right side behind the carpet. If you have access to another antenna, plug it in and see if acquires signal. Vehicle also has to be outside as Sirius signal sucks.
