R-Dynamic Summer Tires
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Leased a 2020 XE R-Dynamic earlier this year, and with the first snow discovered (dramatically) that it came with Summer Tires. No where in the manual or on the sticker does it say this car has tires only good in warm weather. Dealer says we should know R-Dynamic means summer tires. The salesman didn’t even know. So now the car is a Christmas ornament until Spring here in the Northeast. Dealer refuses to do anything. Has anyone else encountered this?
If the car was delivered in December, I could see dealer having to mention to you that it is equipped with summer tires. Otherwise, I see it as being 100% your responsibility to ensure you have adequate tires for winter conditions.
That's the larger issue. There are NO All-Season replacement tires in the required size(s)! I'm investigating Lexani but these are not known to be premium tires.
Received 1,145 Likes
I would not be surprised if the dealership feels the same way.
Typically, in the glove box you should find an Owners Manual. There would be a section titled “Winter Tires” with ample choices of Manufacturer and the appropriate tire size options. I am quite surprised the dealer didn’t suggest these tire options with you. Many Jaguar owners purposely source another set of wheels dedicated for winter tire use. In your particular case, there are tire options in the 17, 18 and 19 inch wheel sizes.
Xistnnn
12-30-2009 09:25 AM
