Radio Frozen "ON". Antenna stuck up - Resolved
1995 XJ6 4.0L
I have had a few issues with "NOT CONT" displaying on the radio intermittently but the CD works 80% of the time. Today, I started my car and noticed the display said CD1 Track 1 but no sound. I went to shut off the radio but nothing! The antenna is up and the radio stays lit with the display showing the same mesage even after the car is shut off. I can't switch to radio or shut it off.
Has anyone had this happen before? Perhaps a battery disconnection is in order? Any advice? Thanks in advance. This is a great site and I appreciate the help.
Allyn
Allyn
Allynmey (04-24-2013)
Success!!!!! I didn't get far. The first thing I check was the fuses. i pulled the Radio fuse in the trunk (15A) and checked it. It was good. When I plugged it back in, the antenna made noise and started to retract. I checked the radio and it was off! Woohoo! I turned the radio on and off a dozen times and it works fine.
Might want to archive this one as a first step in fixing this issue.
Allyn
Allyn
FANTASTIC.
I am a tad rude, mmmmm, YOU ARE NEW, so welcome to our side, sorry for that brain fade.
More importantly, what did you drink as a celebration of a task completed?????????, I will have a nice JD for you later today.
As a side note, when you have another issue with the BEAST, post it in the X350 section, the answers/suggestions/whatever will be thicker and a faster.
ENJOY.
ENJOY.
