Really need help jag s type 2000 3.0 v6
I was driving my car and it’s just died as if the key was just turned of. So I initially thought it was the gas pump so I tested it and it was getting gas but I don’t have a compression test to get the actual specs but I tested the valve and gas shot out,however I couldn’t hear it prime so I just figured I throw a new one in mind you I check all wiring and fuses and relays my inertia switch I checked it all I checked spark so I put a new gas pump in anyways just to make sure. But the new one doesn’t prime either… so now I’m wondering if it could be a camshaft or crankshaft positional sensor but the only problem is no matter what I do I cannot find where these sensors are every schematic is a different engine except for one. Which has a completely different looking sensor the the part on the website for my car so I have no clue what to do now. And through all of this I have no engine light and it just cranks. I tried reading it with my nt7500 scanner I believe is the model and no luck any suggestions!
Tyrjager17 (02-24-2024)
