Rear window detached from to[p
If you mean a 2007 XK this is a known problem. Jaguar even has a repair TSB on the issue which I have attached.
Unfortunately it is a common problem with bonded windows on convertible tops (not just Jaguar).
It can be repaired, even if it is worse that as described in the TSB. See the discussion on this topic here: https://www.jaguarforums.com/forum/x...ble-top-97478/. Some upholstery shops and some windshield shops might be willing to take it on. I think you will find though, that few will guarantee the repair, and they will only do it on a 'best effort' basis.
Next time post in the 2006 and later XK/XKR section to get the correct audience. A moderator may move this post there.
The following 2 users liked this post by WhiteXKR:
24ktairman (08-31-2015),
Jonnyy (08-07-2015)
99xk8guy
06-05-2023 06:28 AM
