Removing Interior Glue
Old 09-14-2014 | 02:03 PM
JohnDredge's Avatar
Default Removing Interior Glue
Hello. Long time lurker, first time poster. Always got great practical and effective answers from this forum. But now I have an odd problem.
Have a 2008 S-Type (not that it will matter). Has a rubber kick mat (pad) under the pedals (w 12' x H 8"). It's OEM apparently because it has Jaguar embedded in the raised rubber matrix. It used to be glued in place over the carpet. Over time the glue lost hold and the pad slides everywhere, now.
There is residual glue (lots of it) on the carpet and I want to get rid of as much of it as possible. Anybody have any suggestions about glue-in-carpet removal? I'm not a knee jerk greenie, but I am very careful, and have access to industrial chemicals. Also have a hot, wet, vac to clean up after applications. I am patient and understand that it might well take more than one pass. Would appreciate effective input. Thanks.
Old 09-14-2014 | 03:54 PM
Fraser Mitchell's Avatar
Cellulose thinners should work. I have used in on the carpet in my boot to remove grease and black marks. It didn't remove any colour, but to make sure, test an insignificant part of the carpet before "going at it"
White spirit will probably also work and is not so strong as cellulose thinners, so maybe try this first. I don't think methylated spirits will work, but am prepared to be surprised.
Old 10-10-2014 | 06:35 PM
jettechbarkdull's Avatar
Default Adhesive removers
I work in the aircraft industry and have been using a product used to remove the glue that is used to hold things glued to the surface of a wing. It will not remove paint and there is very little scraping. I have not used it for carpet but don't see why it wouldn't work. It applies in a jell and dries to a white powder that can be vacuumed off.
Peerco 321 made by Peerless Quality Products in Detroit.
Let me know if it works!
Old 10-11-2014 | 03:42 AM
Welcome to the forum jettechbarkdull,
It sounds an effective product from the information on the Peerless website:
Peerless Quality Products | Manufacturing Chemists Since 1929
The downside looks to be it is only supplied in 1 gallon cans and 4-1 gallon cases.
kevinl
10-31-2019 07:15 PM
1964Daimler
09-09-2015 12:28 PM
davidladewig
09-03-2015 07:32 PM
Dallas XK8
09-03-2015 01:17 PM
King Charles
09-03-2015 01:40 AM
Quick Reply: Removing Interior Glue
