SDD to enable features/modules (MY08 XKR 4.2)
I installed a heated steering wheel and the associated control module in my MY08 X150 XKR yesterday and I gather this requires activating/enabling with SDD. I have SDD 142 installed on a WinXP VM on my laptop which appears to work but I haven't tried connecting it to the car yet. Can anyone point me in the general direction (beyond connecting it to the car obviously) I need to look to find whatever setting needs updated to enable this feature in my car please?
If it's a case of reading the manuals then can someone suggest where to get said manual please, as I don't think my cable and software came with any such thing...
Thanks in advance!
Thanks in advance!
Here you are, you should be able to download from this site;
http://www.mediafire.com/file/x6nmqy...l+02_02_12.pdf
Whatever you do make sure you connect a power supply to your battery whenever the IDS/SDD is connected to your vehicle. If you don't bad things can happen. Good luck.
No the CTek won't do. Yes it's necessary. Myself and possibly others on this forum have tried it without the power supply and experienced "low Voltage" failures. I was lucky in that I was able to eventually recover from the failure. However some have had to have modules replaced and reprogrammed by the dealer, at great expense.
The power supply recommended by Jaguar is the "Midtronics PSC-550". This is the one I have, but others have used a different supply. The point is to maintain a constant voltage level while connected to the SDD.
Here is a link to the one another Forum Member used:http://www.iotaengineering.com/pplib...duct_Guide.pdf
And the one Jaguar recommends;
