Need help programming the amp on a 2012 Range rover L322 autobiography ultimate edit
The original amplifier was broken. I bought a new one from Land Rover and following installation all functions from the entertainment system were restored except the sound.
I tried to program it using SDD version 160.02 v342, but go the below error message:
can anybody please help on how to fix this. I am tired of singing to myself while I am driving
My old amplifier pic is below. I replaced it by a similar one.
Please my audio amplifier stopped working while trying to update firmware.
Originally Posted by enzofl2
Let me know which version of sdd you use.
Let me know which version of premium Amp you use.
Let me know which original version of Highline Amp was born with the car.
Let me know the model and year of registration of the car.
So let's try together to reprogram the premium amplifier firmware. Ok?
Give me time to help, because I'm inundated with work, but I will do everything I can. We hope well
Please my audio amplifier stopped working while trying to update firmware. I’m using launch pad vii
upload a photo of the new unit if you are still struggling.
Hi all I've changed the amp all the speaker and it's all wired in my 2012 xf it had the 600w jag system which was terrible, my mate changed the ccf to premium but I only have dolly and dts on the screen mediriam isn't showing in audio setting is there something els I need to do ? Or do I need the head unit from the same car thanks corn.
I'm in exactly the same situation.
I have no sound.
My amp is the model:
BJ32-19C164-AG
When I try to configure it, it finds the model:
BJ32-14C526-AG
I get the same error.
A failure occured....
So no sound.
Maybe one people have the vbf file?
For the model:
BJ32-19C164-AG
what year and system is in yours ?
my amp ends in BG not AG has you car got a sub as standard? If not you need to change the green plug for the higher grade amp
Reason: More info
Many thanks for your help !
the system dates from 2013 / 2014 i believe the system in BG is the model above
My car is actually equipped with sub as standard.
I think my amp works but it's the update that can't install.
Why update it ? It should never need up dating ? I just changed the amp to the mediriam one put the surround sound in changed the door speakers to meridian and changed the settings to premium. That was it. I know people who have played with changing the software and it bricks the amp. Il see if I can find more on it. Someone managed it to do but not sure if that was just luck. You do have battery supply running while using SDD ?
