SDD help on programming CFF and updating firmware for amp.
Need help programming the amp on a 2012 Range rover L322 autobiography ultimate edit
The original amplifier was broken. I bought a new one from Land Rover and following installation all functions from the entertainment system were restored except the sound.
I tried to program it using SDD version 160.02 v342, but go the below error message:
can anybody please help on how to fix this. I am tired of singing to myself while I am driving
My old amplifier pic is below. I replaced it by a similar one.
Please my audio amplifier stopped working while trying to update firmware.
Let me know which version of sdd you use.
Let me know which version of premium Amp you use.
Let me know which original version of Highline Amp was born with the car.
Let me know the model and year of registration of the car.
So let's try together to reprogram the premium amplifier firmware. Ok?
Give me time to help, because I'm inundated with work, but I will do everything I can. We hope well
Mediriam up grade
Hi all I've changed the amp all the speaker and it's all wired in my 2012 xf it had the 600w jag system which was terrible, my mate changed the ccf to premium but I only have dolly and dts on the screen mediriam isn't showing in audio setting is there something els I need to do ? Or do I need the head unit from the same car thanks corn.
Same situation No Audio / No sound
Hello,
I'm in exactly the same situation.
I have no sound.
My amp is the model:
BJ32-19C164-AG
When I try to configure it, it finds the model:
BJ32-14C526-AG
I get the same error.
A failure occured....
So no sound.
Maybe one people have the vbf file?
For the model:
BJ32-19C164-AG
I have no sound.
BJ32-19C164-AG
BJ32-14C526-AG
So no sound.
For the model:
BJ32-19C164-AG
Up grade
Hello,
I have no sound.
BJ32-19C164-AG
BJ32-14C526-AG
So no sound.
For the model:
BJ32-19C164-AG
I have no sound.
BJ32-19C164-AG
BJ32-14C526-AG
So no sound.
For the model:
BJ32-19C164-AG
my amp ends in BG not AG has you car got a sub as standard? If not you need to change the green plug for the higher grade amp
the system dates from 2013 / 2014 i believe the system in BG is the model above
My car is actually equipped with sub as standard.
I think my amp works but it's the update that can't install.
#31
#32
Why update it ? It should never need up dating ? I just changed the amp to the mediriam one put the surround sound in changed the door speakers to meridian and changed the settings to premium. That was it. I know people who have played with changing the software and it bricks the amp. Il see if I can find more on it. Someone managed it to do but not sure if that was just luck. You do have battery supply running while using SDD ?
#33
Unfortunately, I was stupid enough to do the update, which caused me to lose the sound
Ok I understand better your change which is different from mine.
If you have a solution I'd be extremely grateful
yes i have battery supply running while using SDD, the module is well recognized, but impossible to reconfigure.
#34
https://www.jaguarforums.com/forum/a...-14c526-ba.rar
look at this should shed some light on it hopefully
#37
https://www.jaguarforums.com/forum/x...-wrong-221956/
this is the thread I went through. Other wise new amp.
Il_Boros
02-06-2023 05:27 PM
