SDD locking up at 98% "Data Collection" stage
I don't believe that Win 7 64-bit is supported.
Are you using a Mongoose, a mongooser, a VCM, WDS, or what type of hardware interface to the car?
The Mongoose and mongooser won't support an 89 XJS. I am not for certain about a VCM. I believe a WDS will.
Is SDD being used after the VIN is recognized, or is IDS? An 89 XJS makes me think IDS would be used.
If IDS even supported an 89.
Is the dead transponder the only one you have?
Transponders don't tend to go bad unless they are damaged.
Also, I thought that the transponder key could be programmed without any tool.
Wish I could be of more help.
My system has now started locking up at 98% too...
I found that if you have previously connected to the car, you can re-open a previous session (sessions tab, top right corner of screen) which will skip over the general scan where it locks up & you can go straight to the select symptoms screen. Hope that helps...sorry for the late reply!
philwarner
28
07-11-2017 10:21 AM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
