SDD said it couldnt clear all codes
I had something similar using the same version of jlr sdd with my transmission. I only had the one code which I think it stated it was a "hard code" or fault.
It was a P0730 code which is a "permanent" DTC
Which is why, along with a seal leak, I am going to rebuild my transmission.
Aarcuda (12-12-2019)
I wonder if maybe my battery charger is too high causing the fault. I know its not low because SDD shows the battery indicator as Green in the upper right of the SDD screen.
Any other ideas?
I do have a problem with my front park sensors. SDD shows they should be working but theres no sound.
Unless it's destroyed the battery it's rather unlikely to be too high.
It could have other problems (e.g. too much ripple), but being too high - well, you'd know if it destroyed the battery I reckon.
You can check "too high" fairly easily e.g. is it over 15V when connected? Disconnect it if it is!
and guess what? It actually cleared all the codes for the first time ever! So im gonna say the battery voltage is critical here.
jackra_1 (08-06-2020)
Bladevane
02-11-2014 02:23 PM
