SDD V125 Software
#41
Update…
To recap: I successfully loaded V125 and then went in search of a cable. My car is a 1999 XJ8. I tried the Ford “VCM” cable shown in post #32. No joy. I then ordered and received a "Mangoose" from OBDII365.com for about $40:
As shown, it comes with some pretty authentic-looking Mongoose badges, and comes with a DVD with drivers and a copy of V162. I stuck with V125, and the LED's in the Mangoose change from flashing red to green when connected to the laptop.
In fact, as shown, the SDD recognizes the cable as a MongoosePro JLR.
Also, in the SDD “System Information", it records Mongoose Pro JLR as the Gateway Device. (However, under “Supported Models" it doesn't list X308. It does, however, have X100. What’s the difference?)
So, my car, being a 1999 X308, SDD takes me to IDS. And from there, when prompted to check trouble codes, it freezes:
I let it run for 20 minutes or so, just to be sure it wasn’t just slow-- I'm running a Dell D630 with a new hard drive and clean install of XP Pro. After a few minutes it even shows the MongoosePro disconnected! WTF? Only a hard reboot of the Dell will clear everything.
After reboot, I tried some innocuous tests, like power antenna and courtesy lights, and those seemed to work okay, but I wonder if those are just rote teaching, and not really communicating with the car???
So, I’m pretty close to admitting defeat… Unless, you wise sages have any further advice.
In the recesses of my often-lubricated-with-ETOH brain, I seem to recall a MongoosePro JLR will not work on pre-2000 models, and the original Mongoose JLR is the only one that works (a unicorn)… (Note, the Jag service bulletin on J2534 says the Mongoose JLR is supported, and doesn't use the term "MongoosePro".) Did I just prove this? Or, is it just the IBKB (idiot behind the keyboard)?
And, finally, should I try V162? Or, is that a waste of time on the 1999 X308?
Many thanks to all who contribute… Regards… Mark
#42
#43
Thanks clubairth1:
Yes, I think it is a Microsoft problem...
A little further searching of the program freeze problem...
...reveals I'm not alone. Others using IDS for the first time have had this occur when trying to read codes... Unfortunately, no one has ever posted a solution...
Does anyone have a solution? Sorry to ask again, but wanted readers to know, I haven't found the fix. I'll post if I figure it out...
For now, I might try to reinstalling everything (V125 and Mongoose), and try it again.
Again, many thanks.... Mark
#44
protocolaccessserver.exe Problem Solved (sort of)
Final Update:
To recap (again): After 17 years of ownership, I found the need to program another key, and found this useful thread on SDD V125. I successfully loaded V125 and then went in search of a cable. My car is a 1999 XJ8. I tried the Ford "VCM" cable shown in post #32. No joy. I then ordered and received a "Mangoose" from OBDII365.com for about $40. Then, I ran into the screen freeze described in post #41 (I've included the offending program's name in this post's title because this is a known problem in search of a fix-- at least for those of us trying to use SDD V125 on a 24 year old-- or older-- car for the first time! Presumably, anyone searching the problem on Google-- where I found most of my info-- will come across my fix. And we older car owners need all the help we can get...)
Solved:
I tried several tricks to fix the protocolaccessserver error, like setting the XP firewall "Off", and reinstalling V125 and the Mongoose msi. No joy...
I found and installed IDS_DVD130_FULL with these other programs (the SDD V130 worked without these other programs, but I figured the other programs weren't just included for "cocktail chatter", so I added those too):
No small task to find, download and install these 8Gb total-size files....
Success!!!
This is a screen shot of V130 IDS reading trouble codes (DTC) on a Second scan... Note the blue bar at the bottom with "Please Wait". So, this screen shot shows both the reading process and the result from the previous scan....
Five of the 6 systems were successfully read. (Note, Climate Control Module had an error, and was never able to be read-- not an issue, at least, not for me...)
The 3 DTC's shown in the screen shot were: P1000, and two other old DTC's (Mfg specific) that a generic scanner will not clear, but were cleared in IDS! Who knew??? After 17 year of ownership, my vehicle is DTC-free, maybe for the first time!!!
Now, on to key programming; which I may post elsewhere, so as to not clutter this Very Useful thread...
Many thanks to contributors, and Regards.... Mark
Solved:
Success!!!
#45
ISO Images for IDS125?
Do you happen to have recovery disks for 1stGen IDS set with Panasonic CF-18 ToughBook?
You can create images easy with https://www.imgburn.com/ Its working W10x64 22H2 even it is old software.
PM:ed you the upload link.
#46
They are "in the cloud" which is why I never use online storage for anything personal.
This is the link to the folder:
http://www.mediafire.com/folder/p10k.../JAGUAR_FORUMS
Looks like a duplication on the top one?
I've shared the folder so melhoov12 should be able to download the fileset.
Could you upload .ISO image of original IDS125 DVD?
#47
Don't know if this will help but there are 2 sets of these disc's on EBay? $50 so not too expensive?
Both from the same seller too?
Tough Book Discs
Another Tough Book Disc
Don't know why one is 2 discs and the other is 3 separate discs?
Recovery discs for Panasonic CF-18.
Might be useful??
Panasonic Recovery Discs
Tough Book Discs
Might be useful??
#48
Not IDS Recovery
Tough Book Discs
Might be useful??
Tough Book Discs
Might be useful??
#49
Tough Book Discs
Might be useful??
Tough Book Discs
Might be useful??
Last edited by tlindi; 09-21-2023 at 08:13 AM. Reason: I was not able to test recovery image at the moment
#50
#51
This would possibly help me in reflashing gateway module
Bob,
I've made a shared folder on MediaFire where you could upload the requested SDD fileset.
http://www.mediafire.com/filedrop/fi...641c8bf75f2033
If you want to try it this way, I can then give a link for melhookv12 to download them.
Here you have more recent links:
125.08: https://archive.org/details/jaguar-ids-125.08-dvd
131.03: https://archive.org/details/JLR_SDD131
While you are working with Gateway Module (GWM) I'd recommend you to use original (not clone) VCM-I or Mongoose with Yellow Mongoose text.
br, tlindi
br, tlindi
joeleerj
22
10-05-2023 01:18 PM
Aarcuda
04-03-2020 02:59 PM
Paul2005
01-29-2018 03:31 PM
