Seed codes calculator (SDD engineering mode access codes)
Old 10-18-2020, 02:45 PM
tmich's Avatar
Default Seed codes calculator (SDD engineering mode access codes)
Hi,
Does anyone on a forum have a software which calculates VIN + Seed code = password to SDD engineering mode? I have seen a few people selling this kind of applications (which makes sense once you have a garage, but if you need 1-2 codes a year max, might not be a reasonable purchase) and I was wondering if maybe someone already bought it and can help me with that?
Happy to cover part of an initial purchase cost
Best
Tom
Old 10-21-2020, 05:07 PM
tmich's Avatar
Maybe someone will be searching for codes - sharing what I found. Unfortunately only 2 codes per day, but still a great, free service: https://vehcom.com/jlr/access-code/
Aarcuda (10-22-2020)
Old 10-22-2020, 07:51 AM
Aarcuda's Avatar
Cool! ya I have had this sight bookmarked for a while but never tried it. I think today is the day! I just worry about pushing the wrong buttons and messing up my CCF.
Old 04-13-2022, 11:27 PM
boostedxf's Avatar
I’ve tried this site but it asks for seed. Where do I find the seed? Must I have already accessed SDD to receive the SEED? If so, I’ve tried but it asks for log in to TOPIx and I haven’t quite gotten that subscription yet. Trying to find a way to gain access to any form of JLR Software/ Data to run a true in depth scan/ reset/ relearn adaptions and have access to their OE diagnostics. Any tips? Also I’m running Win 10 x64 bit with the SDD V160 Win10 x64 version/ patch file and a Mongoose Cable.
Old 04-14-2022, 08:59 AM
clubairth1's Avatar
Received 2,427 Likes on 1,907 Posts
Sorry if this is off topic? But will this also work for Pathfinder?
This is my home screen currently;
I can use SDD OK as always but I don't know what all the other things do? Do I need that seed codes to get into Pathfinder or those other Icons?
Old 04-14-2022, 09:17 PM
Aarcuda's Avatar
the video shows the seed is given to you when you click on the ccf button.
Old 04-17-2022, 07:46 PM
xalty's Avatar
Received 1,062 Likes on 853 Posts
SDD before 151 carries onboard vbf and bin files and doesn't have to download from topix. go use 130 on windows 7 with IE8
I have the offline seed calculator if you guys want it. works all the way back to the WDS
The following 4 users liked this post by xalty:
Hampster21 (06-20-2022), kayhandayhan (05-02-2022), TristanM (06-14-2022), Unbeliever (11-06-2022)
Old 04-18-2022, 09:33 AM
clubairth1's Avatar
Boy that would be great! And I do want a copy if possible?
Send you a PM?
Old 04-18-2022, 09:40 AM
tmich's Avatar
Hi, would be grateful as well. Can you share it with me too, please?
best regards
Old 04-19-2022, 04:27 AM
boostedxf's Avatar
Thank you for the information! Are you able to send me the offline seed calculator as well? Any chance you have the software download for 130? Does anyone know if I’m able to run Win 10 or 11 with Win 7 only booted for SDD? I read somewhere that a dual OS is possible. (I’m far from knowledgeable when it comes to the computer realm.)
Old 04-19-2022, 08:35 AM
clubairth1's Avatar
You can try it? SDD is picky and some people have got it to work fine on virtual machines and dual boot machines. Others not at all. With how cheap laptops are I decided to just use a dedicated laptop (Win7) for SDD.
Mine has been working about 3+ years now. Hoping to figure out this coded access stuff using xalty's help.
Old 04-19-2022, 09:19 AM
boostedxf's Avatar
Ya it’s been a bit of a headache figuring this all out. I purchased a PC with Win11 and uploaded Win10 because I found a Win10 x64 patch file but after numerous attempts and trying various Versions I’m now trying to just find out if I can go with Win10 and if so how and how much does it cost? Win7 basic or pro? What about Visual Redistributable c++ version? I tried a 2015, 2019?, and a 2022 but none have worked and the 15’ I believe caused a white screen of death (restart and went away)
Old 04-19-2022, 12:37 PM
clubairth1's Avatar
I use win7 Pro but any Win7 will work.
Thank you xalty and boy does Microsoft make this hard!
Note to anyone trying this. Any Windows machine will fight you trying to save or use this file. It's coded as a Trojan and if your unlucky enough to have Win10 or above the file will be AUTOMATICALLY deleted by Windows WITHOUT telling you. The file will just vanish EVEN if you set an exception in Windows Defender! Pure Microsoft garbage software again and again. It's just such a sad sack of crap even after 40+ years of trying.
But I did get it installed and even now when I run it all kinds of useless Windows security craps pops up. Just close all that junk. Any Windows Defender scans will identify it as malicious and delete it. It has been recommended to me by others to dump Security Essentials and use a real program. But that's even more work so I have not done it yet.
Next I will get it over to my SDD Win7 machine and see if I can generate some codes!
Old 04-21-2022, 10:31 PM
MustangLee's Avatar
Smile Need Seed passcode calculator?
Hello All,
I've been trying to get the SEED Passcode from the this website https://vehcom.com/jlr/access-code/ and keep getting error messages! I'm running V130 on a Virtual XP machine, and am trying to upload the as-built information on my 2013 XJL.
Xalty, can someone provide a link to your offline seed calculator?
Thanks!
Regards!
Lee
Old 05-10-2022, 11:38 AM
clubairth1's Avatar
Don't use this. This is spam.
Please read the rest of the post for proper information.
Old 06-21-2022, 04:15 AM
Hampster21's Avatar
Hello Everyone.
I am after the offline seed calculator.
Will the one you have Xalty work with SDD V162 as i would like to start to investigate the coding options
Steve
Old 08-12-2022, 07:30 PM
xalty's Avatar
for anyone wondering this thing works but does have a trojan, don't run it on your real computer
joseravat (09-10-2022)
Old 08-13-2022, 09:45 AM
clubairth1's Avatar
Again xalty thank you very much for your help and comments. I am sorry to say I have not done any further work on the seed calculator other than help a couple of people get it down loaded.
hafren (08-18-2022)
Old 09-05-2022, 07:19 AM
tomek0674's Avatar
Default hi
can you provide the RBCM .vbf file for jaguar xf 2012-2015 sportbrake 2.2?
Old 09-10-2022, 07:56 AM
joseravat's Avatar
Good afternoon xalty.
If you could send me the seed calculator I will be very grateful.
I bought an old XF and I doing some changes but I need the enginering mode.
Thanks in advance.
Quick Reply: Seed codes calculator (SDD engineering mode access codes)
