Select Edition Warranty Timing
Researching used jags and am wondering about the Select Edtion warranty. From reading here it appears that an extended SE warranty can be obtained anytime prior to buying a car from the dealer. With BMW's , the Certification must happen prior to sale. Is Jag different? Is the SE limited to the first six years from the cars in service date? Are good extended warranties available after the six year period?
Thank you in advance.
Hi, there!
From my experience, I believe the car must be registered by the dealer with Jaguar as a Jaguar Select Edition prior to selling it to you (they will do it for you when you agree to the sale). However, once the sale is completed, I don't believe you can get it certified as a Jaguar Select. Initially, the select warranty will be limited to 6 years (and certain mileage) from the original date the car was placed in service. If you buy the car as a Jaguar Select, I understand you can get the warranty extended as the initial period gets close to expiration.
Hope this helps!
Hope this helps!
jaguny (01-12-2012)
I understand the "Select Edition" is not REALLY an extension of the original Jaguar factory warranty. It is instead an exclusionary aftermarket warranty that Jaguar contracts to provide to its customers on a select basis.
I am told however, it is one of the better extended warranties out there. It just does not cover everything the original 'bumper to bumper" warranty does.
In any case, look at total cost. You might actually do better by purchasing an extended warranty from a reputable company
Just my two cents
Just my two cents
jaguny (01-12-2012)
The other gent had a good point, the Jaguar Select has been known for years as the best in the business for a factory-backed warranty.
Cheers,
Wolfy
05-28-2024 08:06 AM
FS[NorthEast]: 2011 XFR for sale
jgatto
09-21-2015 11:24 PM
