Bdia desd e cdmx tengo problemas con un jaguar xt portafolio mod 2012 no marca el sensor. Tengo señales de voltaje 5 voltios tierra y otra variante d 4 y 5 voltios ya cambié sensor hize pruebas sin aceite marca vacío. !! Agrego aceite y me marca sensor desabilitado. Alguna sugerencia se les agradecería Este es el vin
I have problems with a Jaguar XJ Portfolio model 2012 does not mark (detect?) the sensor. I have voltage signals of 5 volts ground and another variant of 4 and 5 volts and I changed sensor I did tests without oil mark (indicates?) empty. !! I add oil and it marks me a disabled sensor. Any suggestions would be appreciated. .....
Welcome to the forums Rubenspits,
English only on the forums, please. I find Google Translator very useful.
If I am following this correctly, there is NO indication of oil level. You have checked this with no oil in the engine and again after filling with the correct amount of oil. You have replaced the sensor but there is still NO oil level reading.
