Speedo accuracy
Speedo accuracy
Not really a tech problem but no idea how to get a definitive answer
In my experience a speedo will display a higher speed compared to a sat nav readout
My question is where does the sat nav get the speed that is displayed on the unit and is it more accurate than the speedo? - standard size wheels/tyres so no mods to affect the speedo reading
Most modern cars have optimistic speedo's. My Toyota truck and my wifes Subaru are out 5-10kph at 100kph. My older cars (84 and 86) are close to spot on. I think modern manufactures just want not to get involved in court cases and disputes so they default to slightly slower.
Sat nav uses GPS signals to determine your position, which it continually samples. Change in position (distance) / time =speed. I would trust any GPS based system over a modern car speedo for accuracy. You can also download an app (there are many) for your smartphone, which I find handy for an old 1960 car I have which has a grossly inaccurate MPH speedo, that I need to relate to kph speed limits.
DaveJessop (01-13-2017)
Thanks for the answer Steve - I thought the gps would be a bit more accurate but wasn't too sure how often the send/receive data worked - so it's pretty much every second to get a good reading
I agree that modern cars actual speed is a bit lower than the speedo so that people don't go over limits by accident - I was quite pleased when I hit 150 mph in my old Kia but then saw the gps was only saying 139
The Jag is so smooth that 10 minutes after I started driving it felt like 40 mph and looked down and saw I was doing 80 on the clock - normally you can tell how fast you are going just by vibration and revs but that's a bit hard with a 3.0 automatic
DaveJessop (01-14-2017)
Grant Francis (01-16-2017)
Although it calculates 1-20 times per second the output display is set to update only once per second or so. Our brainds are too slow to deal with anything much more frequent.
Car speedos have always been inaccurate but without GPS how were we to know?
Here's a discussion where this poor chap took the news quite badly:
https://www.jaguarforums.com/forum/x...2/#post1602114
The following 2 users liked this post by Mikey:
DaveJessop (01-14-2017),
