The squeaks, rattles and groans dept.
Old 06-03-2011 | 08:21 AM
Leedsman's Avatar
Default The squeaks, rattles and groans dept.
I pu this on Gen. Tech. Help as it's quite common on other Jags., indeed other cars.
THE NOISE: A kind of buzzy-rattle from what sounds like the area around the radio-heater console somewhere, even the glove comp. (Mine is UK so that's to the left).
WHEN: Not when it's cold, but when it's esp. part warm. Affected by certain roads and tyre roar from same.
THE AREA: Turned out to be something to do with the winscreen/shield where it abutts the scuttle area to left of car. Found by stuffing an old towel into crevices various around there, including the demister vent.
THE FIX: I got a new piece of pipe lagging, the kind for lagging 15mmm. pipe as in plumbing. There's two kinds, a soft squidgy plastic foam, and a rather harder kind in pale grey with a smoother surface which can be stuffed into the gap between windscreen and scuttle quite decoratively (I thought). I did the whole width left to right.
A longish journey this morning, all sorts of roads -- no buzzes!
However, having done this kind of thing before, I'm keeping fingers crossed...
Leedsman.
Doug (06-03-2011)
Old 06-03-2011 | 08:57 AM
Doug's Avatar
Do you have an X300 by chance?
I'm sensitive to funny noises and my '95 is making me nuts with a noise just as you've described. I've spent hours trying to track it down.
Thanks for the head's up !
PS- if any X300 owners want to see a list of rattle fixes, just shout. I've traced and repaired many on my car.
JimC64
31
05-30-2016 04:04 PM
Les Sweigart
General Tech Help
12-25-2015 09:02 PM
redxk8
10-04-2015 09:28 AM
inactualis
10-02-2015 12:13 PM
millertic
09-30-2015 09:11 PM
