Super cheap test for ETHANOL!!! Buy it here!
Step out of the car sir and blow here.
Just kidding. Actually that sounds expensive.
This is the easiest and by far the least expensive test for ethanol in your fuel. You will be able to catch the fuel stations lying with this one.
First you will need an empty glass bottle or other fuel proof clear bottle with a screw on lid or a stopper you are sure wont leak or fall out. The Übergeeks may use a nitrile stoppered graduated cylinder if desired. We use orange crush bottles at the dealer. Just be sure it is large enough to hold a meaningful amount of fuel. Using a sharpie or some other marking system that will stand up to possible fuel exposure(my bottle has been in use for 6 months with no deterioration and is marked with sharpie) mark your bottle in 1 inch increments up to 5 inches so it looks something like this. Metric weirdos can substitute centimeters but I would use 2 centimeter graduations, it will be easier to see.
![](http://i798.photobucket.com/albums/yy262/norton69/bottle/ist2_1214853-empty-bottle.jpg)
Now, if you would like to test the fuel that is in your car at this moment you will need to take a sample from the fuel rail schrader. If you do not know how to do this find someone to help that does. Gasoline is highly flammable and should be handled with care. An accident pulling a fuel sample from a hot engine could be catastrophic. If you are not 100% sure you can do this seek professional help. Obviously no smoking anything during this procedure. Collect your sample in a clean fuel can or other suitable fuel proof container. You will need only enough to make up 4 inches in your test bottle so the larger your bottle the more you will need. Here's the beauty of this test. You can test on the fly at your local filling station!!!! Just prepare your bottle ahead of time and take it with you along with a fuel can as it is against the law in the U.S. to dispense fuel into a glass container.
Using a small funnel that fits the opening of your test bottle fill to the first inch mark with clean tap water. Try to be accurate here. Your accuracy will depend on the accuracy of your markings but what we really want to know is whether the fuel we use has more than the government(U.S.) allowed 10% ethanol.
Now fill the rest of your bottle up to the 5 inch mark with your fuel sample again being as accurate as possible. Keep in mind that we are not creating a new rocket fuel, pico-liter pipettes are not necessary. Attach your cap or secure your stopper so that nothing can leak out. Shake the bottle vigorously for 10 seconds or so. Let bottle settle and see how much above the original 1 inch of water mark the new "water" level is. Your water sample has absorbed the ethanol from your fuel sample. Very easy, no? Nearly free.
Now, since you had 4 inches of fuel to start with each inch is 25%. Therefore if the new water/ethanol line is at the 2 inch level your fuel had 25% ethanol. If it is at the inch and a half level you have 12.5% ethanol. I wouldn't expect to see much above 12.5% unless there is a real problem with your fuel distributor but don't forget 10% is the max allowed by law.
Needless to say Jaguars do not like ethanol whether it is legal or not. We don't go around testing fuel samples at the dealer so we can strain the ethanol out and drink it. We test so that we can recommend to our customers to try a different filling station that does not use as much ethanol. Your Jaguar will appreciate it and so will you through better performance and better cold starts when it's 0 outside.
Now that you are done with your test you can carefully pour the now pure fuel back into your car and dispose of the water/ethanol mix with a shot glass(just kidding again, though we do usually pour the fuel back in the can or tank.)!
Received 2,263 Likes
I've also used it in my early 70's Corvette and my other cars for at least 15 years with no ill effects.
I've been using 10% ethanol gas at every second or third fill up in my 4.2 S-type since the day I bought it and have noticed NO loss of power or difficulty in starting with temps as low as -30C.
I'm not suggesting that every Jag owner run out and test a fuel sample. What I am suggesting is that if you have persistent cold start or rough running problems that never seem to be correctable and no explanation can ever be found perhaps checking your fuel is a good idea. In the last 10 years I have asked many of my customers where they buy their fuel. I can tell you which stations local to the dealership are selling good fuel and which are not. Nearly every time I suggest changing stations to a customer I get a call or letter thanking me for making their Jag run better than it ever has. The proof is in the results. Any of you that are blessed with good fuel at every station should be thankful you don't have to deal with a problem that's hard to avoid around here.
Received 3,910 Likes
Real Tech, just a silly question to ask: is there anything special you need to do if you have run this questionable fuel in your car? I only ask as I have noticed my fuel mileage starting to take a nose dive and after seeing this, it may be part of my problem (also thinking maybe the TPS is starting to go due to driveability concerns too). I have gotten gas from NW Ohio gas stations a little bit from when I have been visiting family in Toledo. I used to get about 26-27 mpg on the highway, but over the last year or so, it has dipped down to where I can barely pull 22 mpg on the highway. I'm not driving any differently.
As for your mileage. After establishing a baseline, substitute a different map, mass air, coolant temp etc. sensor 1 at a time and see if any change the mileage. Give each a full tank and reset fuel adaptives at each change by disconnecting negative battery cable at battery post and touching to positive post for 1 second. If you had a friend with another X you could compare readings of various sensors but a larger sample group would be better and again that isn't always easy.
Good luck.
fredd60 (03-21-2012)
metalmarty
09-11-2015 07:05 AM
