Superglue activator
Superglue activator
You may have found that cyanoacrylate glues (superglue) don't 'go off' on some plastics.
There's a darkly guarded secret called Loctite 770.
This is an activating primer intended to allow bonding of even the most diffficult plastic materials with a series of Loctite products but works just as well with Supermarket Superglue.
http://www.loctitehf.com/assets/tds/770-EN.pdf
Use the most microscopic amount, thick coats reduce the bond strength.
Except in the most difficult cases applying to one side only will initiate polymerisation.
