Swap is Complete -- Lincoln LS Engine in My X-type Jag.
First off - My 2002 Jaguar X-Type is a Original 2.5L car...Now has a 3.0L Lincoln LS Engine.......Runs Great ! Lots of Power! ..Low miles toooooo...Sweet!
The Swap:
2004 Lincoln LS 3.0L with 28K miles (super low miles)
Payed $100 for a complete block!! minus trans.
Keep your old engine until your completely done with the swap because you will need a few items from it.
Items Needed from old engine:
keep your old wire harness
Oil Pan
Oil Pick-up
the camshaft that controls the water pump
water pump
oil filter mount
a/c braket
Left Head Valve cover
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
Center Block water outlets/Inlets
thats about it.
Helpful info:
all four Camshafts on the Lincoln engine had same part #'s Stamped on it as my Jaguar engine.
Sensors( Crank, Cams ) are a Match in #'s
VVT the same
The Lincoln LS 3.0L is a total match with just a few parts thats different , just keep in mind that the Lincoln engine was not mounted sidewards as in the Jaguar.
Removal of old engine:
If you want to drop the whole frontend its totally up to you, but i think that is a hard way of doing things and risk getting seriously hurt as you have to jack the front way way up.
I went from the top, just moved wire harness to the side, removed trans bolts and torque converter bolts, front engine mount, exhaust and lift away! its tight so go SSSLLLOOWW..
Here is the pictures of the lincoln LS engine before the tear down:
![Name: Picture012Small.jpg
Size: 39.6 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179503d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture012small.jpg)
![Name: Picture011Small.jpg
Size: 37.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179504d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture011small.jpg)
![Name: Picture013Small.jpg
Size: 50.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179505d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture013small.jpg)
![Name: Picture014Small.jpg
Size: 34.9 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179506d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture014small.jpg)
![Name: Picture015Small.jpg
Size: 42.2 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179507d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture015small.jpg)
Left Head Difference on the Water pump cam, the lincoln engine has its water pump on the front timing cover. ( you will need to swap your camshaft, or if you want a challenge & know how to get that pressed end shaft off you could just swap that )
![Name: Picture017Small.jpg
Size: 65.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179508d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture017small.jpg)
Old & New
![Name: Picture021Small.jpg
Size: 39.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179509d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture021small.jpg)
Same Part Number's
![Name: Picture020Small.jpg
Size: 30.8 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179510d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture020small.jpg)
Front Timing VVT Lincoln engine ( total Match, everything is the same down to the count of teeth on the Chain )
![Name: Picture019Small.jpg
Size: 50.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179511d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture019small.jpg)
![Name: Picture018Small.jpg
Size: 60.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179512d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture018small.jpg)
Oil Pan Difference ( left pan is from the lincoln and NO its not dirty i used it for a drain pan earlier since im going to trash it anyway)
![Name: Picture023Small.jpg
Size: 39.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179513d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture023small.jpg)
oil Pick-up's , you need to swap these.
![Name: Picture022Small.jpg
Size: 27.0 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179514d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture022small.jpg)
after all the swapping of parts, the engine gets put in!( yes i removed everything on the front as i thought i was going to drop the frontend , BUT my GUT told me its easier & safety to go from the top)
![Name: Picture025Small.jpg
Size: 32.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179515d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture025small.jpg)
![Name: Picture026Small-1.jpg
Size: 55.3 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179516d1501303768-swap-complete-lincoln-ls-engine-my-x-type-jag-picture026small-1.jpg)
I do have more pictures, that i will post later.. I also took some time to polish my valve covers......So sweet lookin![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
the total swap took me a few days, just take it slow. what did i gain? a sweet low miles 3.0L say good bye 2.5L !
Oh you do not need to replace your ECU..
anyone has Q's just PM me!
The Swap:
Oil Pan
Oil Pick-up
water pump
oil filter mount
a/c braket
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
thats about it.
Helpful info:
VVT the same
Old & New
Same Part Number's
The following 5 users liked this post by willy-k:
Kasey penrod (07-27-2022),
micki88 (06-17-2014),
Panthro (09-11-2013),
Patterson (05-04-2012),
xplicitwhips (08-27-2012)
Received 2,192 Likes
More Pictures:
Covers of shine!!!!![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
![Name: Picture027Small.jpg
Size: 54.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179470d1501303723-swap-complete-lincoln-ls-engine-my-x-type-jag-picture027small.jpg)
LS & Jag Intake
![Name: Picture028Small.jpg
Size: 29.1 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179471d1501303723-swap-complete-lincoln-ls-engine-my-x-type-jag-picture028small.jpg)
even this semi round things on the intakes are the same with matching part #'s.
![Name: Picture029Small.jpg
Size: 27.5 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/179472d1501303723-swap-complete-lincoln-ls-engine-my-x-type-jag-picture029small.jpg)
anyone needs LS parts??
I have wire harness
Front cover
pulleys
water pump
fuel rail
exhaust
intake with throttle body
oil pan
valve covers
I was thinking about eb@ying everything i have left, maybe i could make my $100 back..
Covers of shine!!!!
LS & Jag Intake
I have wire harness
Front cover
pulleys
water pump
fuel rail
exhaust
oil pan
valve covers
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
Panthro (04-11-2018)
Thanks h20boy, hope it helps anyone out there wanting to do this swap, this was really easy if you have some time and the tools.
BTW the car runs great! Ive been driving it every day since the swap no problems at all..
my last thing i did on my car was taking a plastic razor and took that 2.5L logo off my trunk
The Swap:
Oil Pan
Oil Pick-up
water pump
oil filter mount
a/c braket
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
thats about it.
Helpful info:
VVT the same
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture012Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture011Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture013Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture014Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture015Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture017Small.jpg)
Old & New
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture021Small.jpg)
Same Part Number's
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture020Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture019Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture018Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture023Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture022Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture025Small.jpg)
![](http://i817.photobucket.com/albums/zz93/jaguarforum/Picture026Small-1.jpg)
The Swap:
Oil Pan
Oil Pick-up
water pump
oil filter mount
a/c braket
fly wheel
Exhaust Manifolds
Harmonic Balancer
intake
fuel rail
front timing cover
thats about it.
Helpful info:
VVT the same
Old & New
Same Part Number's
