Urgent !!!Pecus B
Guest
Posts: n/a
Urgent !!!Pecus B
Thinking of buying a x type 3.0 2001
The guy selling it says there is a warning code on the dash Pecus B,
he said it came on when he changed one of the door handles, just want to check if this could be true.
Would like to know what it may be otherwise and if its an expensive fault to fix.Help :-(
Regards Novo
Regards Novo
The display is warning of a fault with the Body Processor Module
"In case any of the messages listed below are displayed on the Message Center this indicates that
the Control Module, (CM), referred to is not programmed correctly and must be replaced by a
new PECUS programmed CM.
Each CM has a code, listed below, which will appear if a fault develops. Each code also has its
own position in the Message Center display, as shown in Illustration 1.
PECUS (Programming Electronic Control Unit) always appears before this type of message.
I Instrument Pack
R Driver Rear Door Control Module
S Security and Locking Control Module
K Passenger Rear Door Control Module
DD Driver Door Control Module
PD Passenger Door Control Module
D Driver Seat Control Module
P Passenger Seat Control Module
B Body Processor Module
E Engine Control Module
A ABS Control Module
T Transmission Control Module"
I Instrument Pack
Received 2,194 Likes
ManoFlem
16
09-25-2015 09:29 AM
Peeam
09-22-2015 05:15 AM
axr383
09-18-2015 11:19 AM
