Windshield heated?
Mine is heated on my XE, and in certain light, (mainly full sun from the front), you can see the vertical wires in the screen. These are very fine wires and don't normally intrude, but can be seen in certain light, as I said. Other thing that tells you it is there is when it is freezing and you have ice on the windscreen. On starting the car, on my XE it automatically switches on the front and rear screen heaters. However, you haven't told us what car you've got. There should also be a switch on the dash for the front screen as well as the switch for the rear screen. The rear screen switch will also switch the mirror heaters on too.
