WSA580 - drag racer style
WSA580 - harder shifts - MOPAR style
Something from the hardcore MOPAR drag racers:
to get harder up and down shifts on a WSA580 install the following MERCEDES parts:
Blue Top Transmission Solenoids
These will increase line pressure and therefore shift firmness in the 5 speed NAG1 Tranny.
#240 270 00 89
I have no idea what the Mercedes application is. Perhaps a AMG model.
Now...
Does anyone know if the differential on a X308 is a 215mm?
And the spline count on the inboard end of the halfshaft?
#240 270 00 89
Now...
Any others?
Is it possible to transplant the X300 Powerlock LSD mechanism into the X308 differential?
If one uses the original ratio, is this just a mehanical drop in then? Meaning no TCU or other electrical changes.
What was the donor car for the one you are running now?
Here is the picture of it (form the newer ones). The pinion of the older types are slightly offset, so you need the older ones also with an offset hole.
As long as you indeed don't change the ratio it is a drop in, many have already done so.
Another option, but probably only slightly cheaper than a quaife for you in the US is to get the LSD from gripper diffs in the UK, this was the first one I used.
plums (08-13-2011)
It is so much easier to figure things out when they can be seen.
The information about the offset is a nice little nugget to know. Is the offset vertical or lateral?
Any comments on the possibillity that the GKN original in the SC cars might have used a silicone based viscous LSD?
Here you can see the offset:
JAGUAR XJ6 REAR SUSPENSION DIFFERENTIAL BRACKET FRAME - eBay (item 130551330815 end time Aug-21-11 21:15:20 PDT)
As far as I know Jaguar has only used clutch type LSDs.
