XF 2010 not accepting Smart fob in fob docking station
Old 01-20-2020 | 04:35 PM
Bulldog's Avatar
Default XF 2010 not accepting Smart fob in fob docking station
Hi Everyone... Two years ago my battery died. On that journey my smart fobs would not sync to my vehicle. In the end, I purchased two fobs from my trusted independent Jag service facility to replace/program the two fobs. All good but lighter in the wallet.
Recently, through a long night and a tow truck ride home...I needed to rely on my smart key docking station to start my car...my smart key was being rejected from the fob docking station. It simply would not seat as it should. I tried two of my fobs recently, with the same result. So I have some time to figure this out, before I bring my Jag back into the service center.
There has been plenty of references to Smart fobs, but I did not see anything exclusively posted on the smart fob not working in the docking station.One post stated that the docking station is not recognizing the fob,so it will not seat.
My only guess is my service center did not check to see if the docking station would receive the new programmed fobs which are working normally in all other areas.
Speculating I need to sync the fobs to the docking station? If I can avoid the service center, great...if not, and this requires the service center to get involved ..so be it. Just seeing if there is a fix that I can make.
Thank you in advance for reviewing the post and any guidance...
NavyBlue
05-17-2019 04:45 PM
Ray1000
06-25-2018 03:11 PM
Fairlane500
01-29-2017 07:24 AM
jdmcomp
08-01-2014 02:08 PM
hawaii
11-18-2012 08:50 PM
Quick Reply: XF 2010 not accepting Smart fob in fob docking station
