xj6 headlight problem.
Old 03-17-2010 | 05:37 PM
stu10's Avatar
Default xj6 headlight problem.
Hi, i have just bought my first jag. A 2004 3.0 XJ6 only to find the headlights dont work properly. Dip beam seems to be on permanantly but main beam only works when i flash them. Can anyone help please.
Old 03-17-2010 | 05:53 PM
the-pm's Avatar
Sounds like you have daytime running light enabled which would account for the dipped beams. This is set from the setup menu on the navigation screen. If you pull the light stalk it will flash but if you push forward they will be fully engaged, worth checking these first.
Philip
Old 03-17-2010 | 06:20 PM
stu10's Avatar
Default xj6 HEADLIGHTS.
Just tried but it says daytime lights are turned off so cant be that. thanks anyway
afterburner1
12-16-2015 01:12 AM
VRB
09-15-2015 09:18 AM
avern1
09-08-2015 07:25 PM
sklimii
09-05-2015 07:04 AM
laserguy
09-03-2015 03:02 PM
Quick Reply: xj6 headlight problem.
